Village Idiot
- Jul 13, 2011
- 26,353
Action includes:
Saiger's Sauce Code Red combines Oxy and Enzyme to the already awesome Saiger's Sauce 1. This unscented formula allows for the addition of deodorizers such as the new Saiger's Cide Lime Citron odor destroyer.
your (hot) truck.
soiled carpets may require up to 3-4 ounces per gallon. Test first so you don't waste this valuable
solution.
at 8:1 setting. If not using a metering tip, it is typically at 4:1 setting: THEN dilute only 4-5 scoops which is 8-10 ounces of Saiger’s Code Red.
This water-soluble deodorizer is a great additive to your cleaning solutions or an after spray for a delightful tropical experience!
Packed full of malodor counteractants, it helps neutralize those nasty odors, or a nice way to complete your clients total cleaning experience.
Directions:
Shake well before using. You can add “Mango Burst Scentsation” to your prespray, rinsing agent, or spray after cleaning.
Mild odors 2-4 ounces per gallon.
Moderate Odors 4-8 ounces per gallon.
Severe Odors 8-10 ounces per gallon.
Product can also be applied with a trigger sprayer, electric atomizer, or pump up type Sprayer
- One 40-pound Pail of Saiger's Code Red Pre-Spray, Retail value: $254.37
- Two Gallons Saiger's Mango Burst Scentsation Deodorizer, Retail value: $49.12
- Free Shipping to the lower 48 States
Directions and Suggested use
Be sure to mix with warm to hot and preferably “soft” water. Don't store more than you need onyour (hot) truck.
Pump up or Electric Sprayer
1 scoop (2ounces) to 1.5 scoops (3 ounces) of Saiger’s Sauce 1 per gallon of warm to hot water. Severelysoiled carpets may require up to 3-4 ounces per gallon. Test first so you don't waste this valuable
solution.
Hydro Force Type Injection Sprayer
Dilute 8 –9 scoops Saiger’s Code Red (16-18 ounces) per 5 quart container with warm to hot water, and meterat 8:1 setting. If not using a metering tip, it is typically at 4:1 setting: THEN dilute only 4-5 scoops which is 8-10 ounces of Saiger’s Code Red.
Saiger’s Mango Scentsation Deodorizer
The Burst of Exotic Mango with a hint of Juicy Orange and fresh Pineapple splash your senses with the new Saiger’s Sauce “Mango Burst Scentsation” Deodorizer!This water-soluble deodorizer is a great additive to your cleaning solutions or an after spray for a delightful tropical experience!
Directions:
Retail value $303+
Free shipping to lower 48
Starting bid $200
Minimum bid increment $2
Auction ends Thursday January 12th at 9PM EST/ 6PM PST
Starting bid $200
