Living The Dream
- Oct 25, 2016
- 3,216
- Name
- Swani
How much does ammonia need to be diluted to use as a red remover?
pedantic
Definition of PEDANTIC
of, relating to, or being a pedant (as in being overly concerned with minor details); narrowly, stodgily, and often ostentatiously scholarly; unimaginative, dull… See the full definitionwww.merriam-webster.com
Pedantic is an insulting word used to describe someone who annoys others by correcting small errors, caring too much about minor details, or emphasizing their own expertise especially in some narrow or boring subject matter.
I always turn to Red One for red spots, but I've ran short this winter and anything I order will be frozen solid by the time it arrives, and Red One doesn't work that great after it's been frozen.What percentage are you buying?
Usually 5% is strong enough.
Too avoid being more pedantic than I already tend to be, I'll assume you know what you're doing by using it this way.
Thank you for the messages and help today Jim! Having a paid consultant that has valuable insight and specialized knowledge has really been an asset.DM or give me a call and I'll give you some more details if you feel you might need them
This is about Red Remover.I’m just glad this is all about Mikey
The 2 part system is designed to spray and walk away. Doesn't need to be rinsed. Will usually work for up to 4 hours or until it evaporates off.I just did this job. Wool carpet. I used the Stain Magic red relief stuff. It has the 2 part mixer spray bottle which I like. Since this was a deep stain, I just wanted to see how much it would even help. I just went one round of spraying and letting it dwell for an hour then HWE. I didnt use an iron or even try further, just cleaned and recomended a patch. But it definitely helped.
