Anyone Else Having This Issue?
srd
This ones only 2 weeks old, happens on my sapphire and mach15 wands gets old
srd
happens?
like it's common on relatively new glides?
are they getting jack'd up with installation?
are they $79.99 "universal fit" several wands glides?
I can dig it.
Have you contacted the dealer to express your dismay?
Maybe they'll send you another?
Not getting jacked up during install, not universal fit glides, distributor just blows it off. Glides used to last atleast 6 months with my guys but now lucky to get a month out of them before the break like that,
  • Sad
Reactions: Dolly Llama
They must not be Green Glides--cause mine have lasted over a year.
If they are GG-- then probably operator abuse.
srd
Ya they're green glides i dont buy the cheap shit and please explain operator abuse when it happens on all my trucks multiple different techs, and the glide is literally 2 or 3 weeks old? Granted my guys are prob harder on them then a owner operator would be but still man couple hundred bucks and it only lasts 2 or 3 weeks i mean look at the pick its hardley even been used
srd
Dont get me wrong the green glides are a much better built glide than the rest as far as fit and finish, what im saying is the corners and supports are a detrimental weak point
srd
I think i may try the hybrid like @Willy P suggested seems like it has more meat in the corners that may prevent the breakage
srd
Expect the be totally crushed by Mikey when he returns from his dirt vacation. Its always user error.
Brother, im just saying what my experience has been, ive been doing this for over 25 years never seen glides break like this so consistently, wether Mikey likes it or not it is what it is if he wants to bash me for it so be it, or maybe he can take it constructively which is how i meant it and maybe figure out why they keep breaking, some of yall may know me from the other boards im not exactly a nube lol. Honestly my reason for posting it mainly was to find out if someone might have a fix for it
Reactions: Mike J and BIG WOOD
The only thing you can probably glue it with other than the superglues is permabond but I’m not sure it would hold up
But if that is really two weeks maybe more ke got ahold of a bad run of teflon. Have you contacted him? Seems like something he would make right
Although there is the possibility that he says you fd it up somehow…it is still Mikey after all 😂
Maybe the new JW Mikey 2.0 will surprise us.
Looks to me, by all the scratches on it, it’s been rode hard and probably put away riding face down on the van floor.
srd
Please enlighten me as to how to use a glide and not have scratches, i mean carpet is installed with tac stripping, guess we could just not clean a few inches away from the wall to save our glides some scratches problem solved lol
Reactions: Luky and BIG WOOD
We don’t avoid tack strip and our glides aren’t all chewed up. Probably because we vacuum and our glides are stored on carpet squares inside the van. Also, we use hole glides which are easier to use, thus we’re not leaning on the wand forcing the glide into the carpet.
Reactions: Living The Dream
srd
How does vacuuming change the tacless holding the carpet? You run a soft material like teflon over carpet with tacless strip its gonna get scratched.
Far as van storage our wands are stored on their sides so the glides not even touching the floor on its face. Maybe im wrong but i dont feel like those scratches from the tacless are deep enough to warrant it splitting like that
How does vacuuming change the tacless holding the carpet? It doesn’t, but it does keep sand and other debris from chewing up the glides. You either didn’t read my entire post, or you just ignored the part about leaning into the wand.
Reactions: srd
Latest Auctions
