- Oct 22, 2012
- 28,254
- Name
- Ron Marriott
Like stirring until it's dissolved.There are ways around that
For thinking individuals
My mind reading skills tells me you had a bad experience with cobbs powermax and or chemspec enzall. Those were the two crappy powders that refused to fully dissolve.I quit using powders in a hydroforce; too many problems clogging. I spend way too much time trying to get it to dissolve, and it still clogs. Went to a pump-up for powders.
I've pre-mixed, allowed to settle for 1 minute, slowly pour half into a sprayer, add more hot water and repeat four times and toss the undissolved sludge away. I have even tried pouring through a mesh strainer and still had problems when I got to the job. All with soft water. This is with all I have tried (none of which someone named). Two different hydro-force sprayers.I mix my powder in a pail, then pour into the hydro-force.
Time to change your product. Powders that I use are Saiger's Code Red, prochem power burst, Procyon, clean free, soap daddy pryme Tyme, haven't had any issues.I've pre-mixed, allowed to settle for 1 minute, slowly pour half into a sprayer, add more hot water and repeat four times and toss the undissolved sludge away. I have even tried pouring through a mesh strainer and still had problems when I got to the job. All with soft water. This is with all I have tried (none of which someone named). Two different hydro-force sprayers.
Had the same with Prochem. Strangely though, I have no issues with my 5-gallon rinses, just add powder and fill up and it always dissolves. (Soap Daddy? Had to look that one up!)
You may want to take a higher dose of Ginko! Your mind reading skills need a bit of help. Though thank you for bringing those to my attention.My mind reading skills tells me you had a bad experience with cobbs powermax and or chemspec enzall. Those were the two crappy powders that refused to fully dissolve.
Try something else. The other powders dissolve good.
Use hot, hot water and your worries are over.I get tired of trying to get powders' to dissolve.
I stir with a stir stick for at least a minute.Had the same with Prochem. Strangely though, I have no issues with my 5-gallon rinses, just add powder and fill up and it always dissolves. (Soap Daddy? Had to look that one up!)![]()
Im swinging the wand again. PT is really helping getting it back to normal. I can move the arm about 70% but the muscles are still very weak. That'll take much more time to build up vs getting the motion back
I use very hot water to the point that my mixing bucket gets pliable. I appreciate your help here on the forum and will revisit trying all of your recommendations. I don't believe it is the current powders I use, but I will slow down and mix, mix, mix... and see if that works. The added solution heat through a hydroforce and convenience of it over a pump-up sprayer would make up for the time I used getting a powder to dissolve completely. Perhaps it is the lack of dilution that is in the concentrate that causes it not to break down. I don't have issues when I use it in a pump-up.Use hot, hot water and your worries are over.
What is your dilution set at on the HF? If you're anything over 4:1, it is harder to dilute it because you're putting in twice the amount of powder. I've noticed that when I mixed at 8:1, it took much longer to properly dilute it. Just a thoughtI use very hot water to the point that my mixing bucket gets pliable. I appreciate your help here on the forum and will revisit trying all of your recommendations. I don't believe it is the current powders I use, but I will slow down and mix, mix, mix... and see if that works. The added solution heat through a hydroforce and convenience of it over a pump-up sprayer would make up for the time I used getting a powder to dissolve completely. Perhaps it is the lack of dilution that is in the concentrate that causes it not to break down. I don't have issues when I use it in a pump-up.
Take it easy, you don't want to do more damage.Im swinging the wand again. PT is really helping getting it back to normal. I can move the arm about 70% but the muscles are still very weak. That'll take much more time to build up vs getting the motion back
I have about 220 coming out of truck.Use hot, hot water and your worries are over.
