- Oct 6, 2006
- 117,322
I know.
You gave me a discount.
I gave you a good review.
If I desired it, I’d work at it as hard as you do.If only you had presence outside of Prattville..
You just don't understand...
Four 01 nozzels don't hit as hard as one o94 does.but I do .... P = F/A
Shut up. You’re ruining the marketing magic.I wanted to say that, but I figured I just needed to wait for others to come to the same conclusion.
Plus, with a higher single jet, you're getting heat loss.
Whoever is making this wand is wasting time and money.
Larger water droplet size.can you math that for me? How are you getting more impact (force) by spreading the force over a wider area?
This is quite literally how you decrease "impact"...
You got it wrong…Pre examine, Pre Vacuum, Pre condition. Post extraction, Post speed dry with air movers. Most carpet cleaners do not understand the Pre and Post of the art of carpet cleaning. They just want to pop in and pop out and grab a check.
I would have to agree. I prefer the Slot glides on commercial work. But, on my well maintained apartments and residential jobs, I am quite impressed with the Hole glide. I use the evolution with slot on commercial and the chosen wand with holes for the good jobs.When the glide phenomenon game on the scene I used both hole glide and slot glides interchanging every know and then. Then tried hybrid. Eventually got tired of stopping, bending down to grab those pesky paper clips so stuck with slot glide. Picks up way more then hole glide. With Hole glide you’re just gaining greater air velocity intake sucking in water droplets faster.
Me, I get better results (with and without prevaccuming) and suck in more solids within the carpet with slot . Better results then hole glides.
Yes hole glides slide and glide easier on the surface…but if you can’t push and pull a slot glide, maybe try stretching the body, pushups, pull ups, free weight training…man up put the doughnuts and twinkies down.
I’ve never seen a carpet so bad that I won’t dry vacuum it. Urine, poop, vomit, it doesn’t matter. If it’s wet, I vacuum around it. My vacuum is a tool. Not an idol.
Yeah whenever used flossing picks fall on the floor and left there til the carpet cleaner stops by, yeah gross.I use a Hole 90% of the time, just because it dries quicker.
The Slot gets installed ( in 2.8 sec) when the carpet is so gross I won't dry- vacuum it.
