Is anything missing from this discription of the HWE process?
Cleaning Professional
EXTRACTION METHOD
Dry vacuum all areas, with extra passes made in high traffic areas. A north/south/east/west pass pattern is recommended to achieve the best result. Keep in mind, most vacuum cleaners remove the most particulate soil when the machine is being pulled toward you, so slow down during this stage.
Application of pre-spray formulated for heavy soil and synthetic fibers.
Use a 175 or OP machine equipped with a Fiber Scrubbing Pad to agitate. CRB machines can work in lighter soil conditions but are too lightweight to break greasy soil loose in most situations, regardless of how stiff the brushes are.
Allow for dwell time
Extract with a wand designed for specifically cleaning pile or glue down carpet. Extraction wands should be modified to the task at hand in regard to jetting, flow rates as well as glide type. (see section *** for more info)
Use of a rinsing agent that has cleaning ability as well as being able to neutralize high pH pre-spray is recommended
Perform extra extraction strokes with your wand strokes if results are unsatisfactory, followed by addition dry extraction passes.
Repeat steps 2 through 6 if needed. A Rotary Extractor may be needed in extreme cases. Be sure to feel the carpet after using an “RE” to determine if any additional dry strokes from your extraction wand will be beneficial, which is often the case, especially on floor with unlevel concrete subfloors.
A floor machine and a cotton blend type pad to go over the area again to remove additional soiling and moisture may be beneficial as well. This last step process is known as “Post Padding”.
Use air movers to facilitate quicker drying if needed as wicking is very common in these situations.
*With any method or procedure, it is up to the operator or technician to determine if any warranties are in place that may have set limitations on how aggressive one can get with both chemistry and agitation equipment.
Reactions: KevinL
no.
Mikey's Standards
OK
There were some minor points that might be considered more of an opinion, and a few that might cause irritable bowel syndrome with the carpet manufacturers.
I happen to be on your side with those issues, so don't have any IBS over my comments either.
I just dealt with the whole standards thing back when I had more hair and less brains, and I know how it gets picked apart by "the suits".
Reactions: KevinL and SamIam
the S100 is up for reveiw..
Feels like we just finished the last review.
I can't think of a reason for me to join the new committee.
Reactions: Jim Pemberton
Just break some bottles out in your yard and run over the glass shards in bare feet.
It will hurt less, and you won't have travel costs
Reactions: KevinL
I would mention the importance of pushing forward and pulling the wand back in the same exact path to prevent overwetting the carpet that would cause browning and foul odors.
It’s crazy how new technicians can’t comprehend the process after you explain it to them and they keep making those wet triangles
My room at The Palms was shampood...
I'll keep my boots on.
  • Sad
Reactions: KevinL and BIG WOOD
I see she is holding the favorite piece of technology that every employee of a carpet cleaner uses constantly......
That is as telling as the technique
She was using it to translate my questions as she didn't speak a lick of English...
Now that is a useful purpose for her to have it.
So....they were feeding shampoo through the shampoo tank and scrubbing it in with no system of recovery at all?
I would argue, in a residential setting the use of 100 lbs scrubbers is nil.
If chemistry and heat aren't breaking it free then nothing is.
The crb great for working the pre spray in and getting dog hair out.
If a carpet actually needed a 175, I would use a RE instead.
Guys going from 2 inch wands down to 1 1/2 inch wands with whips to relieve stress, then roll out a orbital machine?
I know ramps and wheels.
A 10 inch crb makes it off the truck, the other things!
To much fatigue.
Did you get a look at what was in the shampoo tank?
Back in the "bonnet cleaning days", Jan-San manufacturers produced products made for bonnet cleaning that could also be used as traffic lane presprays. It didn't take long for any traffic lane prespray to become the standard for bonnet cleaning in the commercial/institutional marketplace.
I would be willing to guess that whatever is being used in that scrubber was bought on price and perhaps performance, but with little concern about resoiling.....
.....our how it might affect you delicate feet and toes.
Only noticed a Brady lable on the machine..
Brady Janitorial is huge, and located here in LV
