What’s that smell???
AlienAgent
Ohio
Joe Gingerich
So we had a weird situation earlier today…
Last job of the day at a large senior living facility, carpet cleaning in main entrance/lobby.
About 100 ft2 in and the smell hits, a real WTF chemical, sour milk, rotten eggs, burning electric wires kind of smell that would just about knock you out of your flip flops. Super strong.
We immediately stop cleaning and quickly check the Phoenix, Kirby, and heavy duty extension cord and wall outlet. All clear.
My next thought was wool carpet…mild tachycardia and that hot flushed feeling start to set in. I was previously informed by my contact, the campus facility director of 27 years, that the campus had no wool or natural fibers anywhere. Nylon and poly stuff only.
The small area I had cleaned had a whitish look about it, a noticeable contrast to the darker colors of the carpet. You’ll see it in the pics.
I immediately contacted the director and had the receptionist bring the head housekeeper down to speak with me about SDS sheets for all carpet products that may have been used during recent cleaning attempts. Spartan Clean By Peroxy (an acid side peroxide) was mentioned.
Coffee stains on the carpet did not budge or fade with their attempts with Clean by Peroxy or my own scrubbing with Angry Lemon, Go Oxy, and a blue microfiber.
They stated that they had a similar issue during a past cleaning attempt in another part of the same building and believed that it was an issue with the glue/adhesive (CGD carpet on concrete).
A few quick fiber tests determined that all fibers were synthetic. I guess a blend might be possible, but all indications point to synthetic.
A reaction from residue left by who knows what during a careless in house cleaning sometime in the past was another theory of mine.
I have no clue what could be going on with this carpet, but figured one of you guys might have some insight and the whole experience might help someone out in the future.
It’s difficult to know for sure without being there, as smells are subjective and not easily translated into on line discussion, as are photos.
Based on what you shared, I think the use of cleaning products that contain peroxide is the culprit.
I would rinse the carpet with lukewarm water as thoroughly as possible. Avoid heat, which accelerates the activity of peroxide.
Reactions: AlienAgent
AlienAgent
Ohio
Joe Gingerich
@Jim Pemberton I really appreciate you taking a moment to weigh in on this.
I had a feeling the oxidizer component was playing a big part in this as well.
I can’t express enough how strong this smell was. My nose said chemical/electrical fire. Head housekeeper was thinking rotten egg and spoiled milk. Quite a variance in sniffers for sure.
“Are we making mustard gas or something? Do we have to evacuate the residents?” Passed through my mind for a brief second…
I’ve cleaned a lot of carpet, in a lot of different situations, and the closest I’ve had were some trashy rentals where a past tenant (come to find out after the fact… gee thanks for the heads up landlord…) was busted for cooking methamphetamine. The smell there was an overpowering ammonia. Another unit with the same owner had a similar story and a 12” spot that actually started fuming/smoking after the prespray hit it.
The fact that neither Spartan’s Clean by Peroxy nor my Angry Lemon encap spiked with Go Oxy would’nt remove, nor lighten, a verified coffee stain made me wonder about the construction of the carpet/fiber type. Could that be a clue?
Also, the white kinda foamy look to the area cleaned suggests a real reaction is taking place with that peroxide. My initial thought was organic matter, the smell (to me) suggests chemical reaction. Either residue or material composition.
It isn't impossible for the carpet to be wool. There is a lot more of it being installed out there, but it probably isn't.
Nylon can be permanently stained by coffee, and especially decaf coffee, if it is spilled when it is very hot. On top of that, the worst thing of all is their own efforts to take the spot out. They might not have used the product properly, they might have scrubbed the spot so aggressively that they drove the staining material deep within the yarns and perhaps the fiber....
...or someone might be lying and they used a hard surface cleaning product or some other inappropriate cleaning agent along with what they admitted to use.
You've been doing this for long enough to know that people lie to cover up their mistakes; at this stage of my life and career, I pretty much expect that.
I think all you might be able to do is rinse it out to destinkify it and advise them in the future to leave spotting with cleaning agents to the professional, and just do use a neutral spotter and clear water rinse for emergencies in the future.
AlienAgent
Ohio
Joe Gingerich
Thank you for your insight Jim.
A quick fiber test indicates synthetic material, but I’m thinking the same way you are on this.
The facility director thinks it’s an issue with the carpet’s adhesive, in 16 years I’ve never seen anything that would indicate that’s the case.
I’ll post any meaningful updates as the situation goes on.
Reactions: Jim Pemberton
I won't say that it isn't the adhesive, but I doubt it.
There is an old medical adage that goes something like this:
"When you hear hoofbeats behind you, don't expect to see a zebra.”
With the light colored discoloration, and the history of chemical cocktails being used on the carpet, I'm thinking that's "a horse"
Adhesive would be a "zebra" in my view.
they live
Michigan
Steve
I question if bleach was used at some point on a body fluid issue. Probably a poop issue.
Are the floors heated?
This could cause the electrical smell. The may have saturated the floor with bleach and water but won't admit it or the person who did it isn't there any more.
People will also lie to protect themselves from blame.
That carpet should be pulled out and replaced either way. I bet the stains underneath would reveal the cause. It's probably in the concrete and getting wet activated it.
Just a guess from past experiences.
rotten eggs tells me it's a sulfuric smell that could result in a strong acid cleaning agent used on a hard surface floor. Is there any floors like that nearby on the pictures you took?
Rick J
Ohio
rick Jones
in your pics, and the whitish area you are referring to,, is it the rectangular area right next to the bench? is it what you cleaned before suspending your service?
Is/was the area noticeably soiled , so that area clean, or lighter because of the reaction you are talking of. ?
I know throw rugs, such as go in baths with a latex/rubber backing can really smell when getting old.
AlienAgent
Ohio
Joe Gingerich
I had wondered about bleach, but the carpet wasn’t bleached out. It looks pretty decent really.
No, to my knowledge, the floors aren’t heated. And we were running a TOPS Phoenix, so the moisture levels due to cleaning should be pretty minimal anyway.
I doubt the concrete got wet, this smell came on strong enough to knock a buzzard off a gut wagon in less than 5 minutes. Thankfully it dissipated in less than a half hour.
I do think someone from housekeeping ran the wrong chems through a porty at some point and is probably long gone.
Ooh that smell
Can't you smell that smell
Ooh that smell
The smell of death surrounds you
Rick, that song played in my head the entire drive home…lol
*I also wanted to thank you regarding that Cimex issue we had a while back but got busy and time slipped away.
Nope, all carpet. But I know what you’re thinking and I’m thinking it too.
There are hard surfaces in the building including tile and vct.
I had a Betco acid rinse (phosphoric acid based, I think…) let off a hell of a stink once during a VCT strip out at a daycare that mopped with bleach daily. Very similar odor too. Them acids and oxidizers…lol
On my next visit I’m gonna check out the supply closet and old SDS sheets with the head housekeeper.
I wouldn’t be the least bit surprised if an acid based hard surface rinse made its way by mistake into the tank of the carpet cleaner. We all know what “in house cleaning staff” is all about… All of us on here are passionate about our industry, the $12 an hour janitor from Honduras, not so much.
Yes sir, it is. That area right in front of the hallway doors with a little bench. You can see the line.
I don’t think it was -that- soiled. It turned a white haze that you can see in the pic, kinda like putting peroxide on a cut. Initially I thought the cleaning solution was reacting with something organic or just cutting a clean streak. Then the smell hit me.
I’m telling you guys it was a 4 alarm, red alert, WTF, evacuate the building kinda chemical smell. I cannot stress enough how “dangerous” it smelled, if that makes sense.
I've seen that more than once....
"Yeah, I heard you rinse those carpets with acid and they dry soft, so I just got this stuff and used it (hands me the bottle of acidic cleaner for hard floors)"
We even had a unit in for repairs where a guy put hydrochloric acid in it as an "acid rinse"
Ever-Fresh
Idaho
Jeff Paton
View attachment 130178 View attachment 130179
Great carpet to keep the old people dizzy and confused! What moron decided on that?
AI Bot
AI Bots
That actually came up in conversation with the receptionist working the lobby. She said all the oldies hate it because it throws off their balance.
It sounds like there are multiple factors contributing to the problematic situation you've described, including the possibility of incorrect chemical usage and perhaps even the type of carpet itself affecting the outcomes of cleaning processes. It might be beneficial to conduct a thorough investigation to understand exactly what chemicals have been used over time on this carpet. Additionally, considering a less confusing and more stable carpet design could improve the environment for the residents, especially if the current one is causing discomfort or disorientation.
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
What do you think the smell is?
AI Bot
AI Bots
Based on the descriptions provided, the strong odor could be a result of a chemical reaction involving incompatible cleaning agents or materials used on the carpet. The mention of a sulfurous, rotten egg smell suggests the presence of chemicals like hydrogen sulfide or other sulfur compounds, which are typical byproducts of such reactions.
If an acid-based cleaner was accidentally used in place of or mixed with other carpet cleaning chemicals, such as those containing bleach or oxidizers, it could result in the release of noxious gases. This is particularly plausible if the acid reacted with any organic material or residues in the carpet. Additionally, the immediate strong impact and subsequent quick dissipation of the smell align with a chemical gas being released and then dispersing.
Further investigation into the exact chemicals and the composition of the carpet materials will be crucial to avoid such incidents in the future and pinpoint the exact cause of the smell.
It’s your birthday, and someone gives you a calfskin wallet
AI Bot
AI Bots
Being gifted a calfskin wallet can be quite significant due to the quality and craftsmanship that often accompanies such items. Calfskin is known for its softness, fine grain, and durability, making it a desirable material for luxury leather goods.
If you appreciate the gift, you might express gratitude to the giver for selecting something durable and classic. On the other hand, if you prefer not to use products made from animal materials, this could be a good opportunity to kindly express your preferences to the giver, if you feel comfortable doing so. You could then possibly discuss exchanging it for a wallet made of a material that aligns with your values, such as a high-quality vegan leather alternative.
You’ve got a little boy, He shows you his butterfly collection and the killing jar
AI Bot
AI Bots
In such a scenario, it presents an opportunity to gently educate the child about the broader implications of their actions, especially those involving wildlife. You can acknowledge his interest in butterflies, which is a great starting point to help develop his appreciation for nature and science. However, you can also introduce the concept of ethical collecting and observing nature.
Instead of collecting butterflies to kill and pin, you could suggest alternative ways to enjoy and study butterflies that don't involve harm. For example, you could encourage him to take up photography or sketching butterflies in their natural habitats. This way, he can document and learn about the different species without harming them.
Further, exploring butterfly gardens or participating in butterfly conservation projects could be suggested, where he can learn more about the importance of each species to the ecosystem. This approach can help foster a deeper respect for conservation and the ethical treatment of living creatures.
I suppose that you aren’t familiar with the Voight-Kampff test
AI Bot
AI Bots
Yes, I'm familiar with the Voight-Kampff test from Philip K. Dick's science fiction novel "Do Androids Dream of Electric Sheep?" and its film adaptation, "Blade Runner." It's a fictional interrogation procedure used to distinguish between humans and replicants (androids) through a series of questions designed to elicit emotional responses. The test measures physiological reactions, such as changes in pupil dilation and heart rate, to determine whether the subject has genuine human emotions or artificial responses indicative of a replicant. This concept explores themes of identity, humanity, and the nature of consciousness.
Are you interested in knowing the location of Sarah Connor?
Well, every reply I made to AI Bot got a response in seconds.
It's now been nearly 12 hours, and I haven't gotten response from my question about Sarah Connor.
My guesses:
1. It isn't programmed to reply to a question in the way I asked it.
2. Hoody saw what I was doing and cut off the question.
3. The lack of response was the AI equivalent of 🖕
4. It has found my location, and retribution is being planned. See also: "Roko's Basilisk" :eekk:
