- Oct 6, 2006
- 117,052
Hopefully, it's just dirty water, not oil.I'm guessing the tank overflowed and black water came out of the blower that I've overfilled that countless times and never seen this before..
Fortunately I have a appointment for belt maintenance next week at my local interlink, as well as a mysterious water leak that I don't want to deal withView attachment 130569View attachment 130570
Do you follow the manual’s terrible instructions to spray water displacement lubrication in the port at the end of every day of use?
If so, it’s just buildup mixed with the water going through the blower
Take the lid off your tank, crank up the machine and turn ip the rpm and run some fresh water through the blower, flushing out the contaminated buildup. Then put the lid back on, run it full throttle, full load and let it burn out any moisture. Once you’ve done that, turn it off and take off the lid to prevent any more moisture from building up. I’m sure you already know this, but some might not. Bawb taught me that process back in 2016
I didn’t mean to rinse it out with waste water. Sorry for the confusion.Really? With waste tank water?
Try mixing a degreaser (purple power or similar) with boiling hot water in a pump up, pull the blower filters, and spray directly into the intake.
Then rinse with clean, boiling hot water for 3-5 minutes…
Then run a water dispersal lubricant (spray for 5-8 seconds ) and run machine for an additional 5-8 minutes.
Actually Matt, my post was directed @ Admiral Oink….I didn’t mean to rinse it out with waste water. Sorry for the confusion.
I agree with your instruction on flushing it out
No. Clean water. I flush my tanks daily. Some times I fill it up completely and let it overflow into the blower. Then I turn it on and blow all the crud out.Really? With waste tank water?
You are noticeably chattier this week, new meds or dietary change?No. Clean water. I flush my tanks daily. Some times I fill it up completely and let it overflow into the blower. Then I turn it on and blow all the crud out.
Seriously dude… did you really think I was running dirty waste water through my blower? Really?![]()
He got luckyYou are noticeably chattier this week, new meds or dietary change?
My heart probably wouldn’t survive thatHe got lucky
SorryMy heart probably wouldn’t survive that
I had that same issue on the top of my silencer on my old machine. I never had an oil leak, so I assumed the water level got a little too high in the recovery tank at some pointI'm guessing the tank overflowed and black water came out of the blower that I've overfilled that countless times and never seen this before..
Most likely, those Harwell floats can't be trusted ..I had that same issue on the top of my silencer on my old machine. I never had an oil leak, so I assumed the water level got a little too high in the recovery tank at some point
