New van or rebuild
Mr Brightside
Southern Cali
Jay Wags
Metal in the oil and some engine noise I have been told it needs a new engine around 9k to put new long block in
I own all my equipment haven’t had a payment and it’s nice but I’m thinking about buying a new van
Would you fix it and drop the cash or trade it in and get a payment
Nothing we say can be a good suggestion. It all depends on your finances. If debt is high in your boat, just put a new engine in it.
Prattville, Alabama
I paid around that same price to replace the engine in my 2015 GMC and for the same reason. Happened just out of warranty. I used to get a good ten years out of my Chevy vans before things started breaking. I’d replace them as soon as small things like starters or fuel pumps started breaking. Now a days your lucky to get two or three years out of them before they start needing shop time and it’s not always small things. Heck I’m having to replace the upper and lower ball joints on one van right now and that used to be unheard of. I had to replace a front tie rod last summer and I noticed the inner joint didn’t come with a grease fitting on it. I pitched a fit and my auto parts buddy told me to calm down. The planning to fail is just going to get worse.
Payments suck
Warranties don’t
Mr Brightside
Southern Cali
Jay Wags
I have no debt I like to run things as long as I can but I am at 86k miles on this van and am afraid I’m gonna just keep dumping money into it but at the same time I don’t have too much faith in the new stuff either
The problem is the wrap and install is gonna make everything more expensive to swap
Mr Brightside
Southern Cali
Jay Wags
Payments suck
Warranties don’t
Wow that’s crazy
This is how I feel I had direct drives with 150k miles and 5-6k hours and still all original except normal things like spark plugs belts pulleys ect
This van has an Everest in it and less than 90k miles
I am thinking maybe a low top transit but not sure if it would be reliable either or just replace with the newer Chevy and pray the new 6.6 gas engine is better
Wow that’s crazy
How many more years do you plan on staying in this business?
Prattville, Alabama
I have mine wrapped too. I started to remove the wrap to sell it a couple of years ago but the paint was coming off with it, so I stopped. I’ll have to paint it when I finally remove it,
Prattville, Alabama
Wow that’s crazy
I’m open to any make van but I only have Ford and Chevy in my town. So, I’ll most likely have to buy a Chevy or GMC just because I don’t want warranty work to be an out of town hassle.
Payments suck
Warranties don’t
To be fair, you had lawnmower engines then PTO's... 4.8, 5.3, 6.0 LS engines are a dime a dozen..
Jasper engines have crate engines.. 1 day to pull and re-install..
The clutch on my Steam Genie fried on a job.. I had to pull the shaft and change the bearings because I didn't know if it was just the clutch and/or bearings.. @Dwain Ray is the real MVP, came in clutch with walking me through the steps to change it.. He even sent me his installation tools to speed up the process.. Rather simple after figuring it out..
