icleancarpetz
- Mar 7, 2015
- 1,698
- Name
- Rafael Samson
Pros and cons?
Pain in arsh?
What are you guys charging per sq?
Pain in arsh?
Usually about $2 per square foot. It can be a pain. Bring soft tarps to protect from the hoses. I have done 150 ft yachts as well as smaller 30-40 ft yachts. Minimum charge is $300. If you have to do it with a portable, check to make sure you have enough electric power and hot water.Pros and cons?
Pain in arsh?
Exactly!been there, done that. Kinda like cleaning private jets. a long hose run and tightly cramped. not really fun for someone 6 ft 7 inches.
And make sure it's secured if left on the dock. I heard a story about a local cleaner that had a portable vibrate off the dock into the water.If you have to do it with a portable, check to make sure you have enough electric power and hot water.
Exactly. Check the tide table before scheduling as well. You don't want to rolling a heavy portable down a steep ramp at low tide.And make sure it's secured if left on the dock. I heard a story about a local cleaner that had a portable vibrate off the dock into the water.
We have done all kinds of boats and airplanes over the tears, including the guest suite on a 750 foot lake freighter. I went on that one because it sounded fun and it was!
Can you imagine trying to push a full Bane recovery tank up a boat ramp.I have no idea. I think they are. They used to show an ad with a Bane porty just outside a yacht with the hose running to it. Can you imagine trying clean in one with a Jimmy wand?
Always thought that would be a great idea. Yacht owners would pay extra for a boat mount. With the amount of marinas around here, the right person could make a killing. We also have a few large float home communities. You can pull right up to their dock and away you go. Probably need something like a 30 foot aluminum boat with a lot of rear deck space, like a crab boat. Run the truck mount off the boats engine. Probably never need more than 150 feet of hose. Lots of large bumpers and Bob's your uncle. Or Bawb.YES YES even in sunny Florida a PAIN . Years back there was a guy that had a truckmount in a boat and was able to clean by pulling up next to the boat to be cleaned on a calm day no wakes.
I have seen it happen to our crews.It would probably vibrate into the water
What about winter in your area with that kind of business model? It would have to be a summer season only and just go all in 7days a week to make it a good quick cashAlways thought that would be a great idea. Yacht owners would pay extra for a boat mount. With the amount of marinas around here, the right person could make a killing. We also have a few large float home communities. You can pull right up to their dock and away you go. Probably need something like a 30 foot aluminum boat with a lot of rear deck space, like a crab boat. Run the truck mount off the boats engine. Probably never need more than 150 feet of hose. Lots of large bumpers and Bob's your uncle. Or Bawb.
Fallacy; there is no spin. Simple experiment disproves the fallacy.See! The spin of the planet would just roll them in![]()
Winter here is pretty mild usually. More rainy than freezing temperatures.What about winter in your area with that kind of business model? It would have to be a summer season only and just go all in 7days a week to make it a good quick cash
