Anyone Yacht carpet cleaning
icleancarpetz
Rafael Samson
Pros and cons?
Pain in arsh?
What are you guys charging per sq?
Pros and cons?
Pain in arsh?
Usually about $2 per square foot. It can be a pain. Bring soft tarps to protect from the hoses. I have done 150 ft yachts as well as smaller 30-40 ft yachts. Minimum charge is $300. If you have to do it with a portable, check to make sure you have enough electric power and hot water.
sassyotto
Paul
been there, done that. Kinda like cleaning private jets. a long hose run and tightly cramped. not really fun for someone 6 ft 7 inches.
Brian H
Brian H
And make sure it's secured if left on the dock. I heard a story about a local cleaner that had a portable vibrate off the dock into the water.
We have done all kinds of boats and airplanes over the tears, including the guest suite on a 750 foot lake freighter. I went on that one because it sounded fun and it was!
Exactly. Check the tide table before scheduling as well. You don't want to rolling a heavy portable down a steep ramp at low tide.
I cleaned a houseboat at Lake Shasta. The guy docked it near the launch ramp and I parked my van on the ramp near the water. It was a real pain in the rear. The thing that stuck with me is the customer told me to dump my waste water into the lake. Unbelievable to me. Can you imagine the fines for doing that? Probably would have had some sort of federal charges. Needless to say, I didn't do it.
I turn down all boats and RV's now. Just give me regular carpet in houses.
jack zerkie
YES YES even in sunny Florida a PAIN . Years back there was a guy that had a truckmount in a boat and was able to clean by pulling up next to the boat to be cleaned on a calm day no wakes.
  • Wow
Reactions: hogjowl
I have no idea. I think they are. They used to show an ad with a Bane porty just outside a yacht with the hose running to it. Can you imagine trying clean in one with a Jimmy wand?
I can’t even imagine setting up a vacuum hose up a boat dock. It would probably vibrate into the water 😂
Always thought that would be a great idea. Yacht owners would pay extra for a boat mount. With the amount of marinas around here, the right person could make a killing. We also have a few large float home communities. You can pull right up to their dock and away you go. Probably need something like a 30 foot aluminum boat with a lot of rear deck space, like a crab boat. Run the truck mount off the boats engine. Probably never need more than 150 feet of hose. Lots of large bumpers and Bob's your uncle. Or Bawb.
What about winter in your area with that kind of business model? It would have to be a summer season only and just go all in 7days a week to make it a good quick cash
Winter here is pretty mild usually. More rainy than freezing temperatures.
