Has the zipper wand been knocked off the throne?
Steve Lawrence
I don't think it was ever on a throne. If anyone tells you they use it on every job...either their full of shit or they aren't cleaning carpet properly. It's too bulky to clean in tight spaces
But on the big open spaces, it gives your shoulder a break and is a need for those type of jobs
i once did a big church job with my son. I probaly cleaned 2x what the other crew (much younger than I) only cuz I had the Zipper and they had wands. (I admit that had big wide open areas but so did they.)
Mike J
Mike Joannides
Is this a Zipper? I think MikeyP might still use em
Mr Brightside
Jay Wags
you guys are silly either you don't do a ton of commercial or you switched to the darkside vlm.
you don't need or wont like them if you are 99% residential but if you do commercial all the time it is the best
What PSI are you using in this video?
Will 12.6-13 inches of lift be enough to run this wand?
It's been a while...
Don't I say the psi in the video?
What truckmount do you own and what are you looking to do with a zipper, and are you interested in the spinner or the regular model
Speaking of, since the question has been answered, and Chavez is mentioned 😬 Does Marty or Mike know if he's still working at the university, or at all? (thread robber)
You don't work at a school, so you can't say😬 Residential, schools, all the same misery😏
Numero Uno
Caesar
It's throne is found in every house in America-The Bathroom -Wand over All. The individual bright carpet cleaner need's it not...Extra time on job, charge for simple. Regards. Add a quality glide your set fer life...
icleancarpetz
Rafael Samson
A nice light weight wand designed with airflow in mind (instead of looks) coupled with #4blower spinned by 27 kohler command in the right hands…..hard to pry my hands away from my Mach12 wand.
Good to see u bro…
Reactions: Numero Uno
sassyotto
Paul
Had a Zipper when I did commercial. Two years I quit commercial so I sold it. Then just a couple weeks back a church calls and wish I kept it. So I bought a used one just for this job because I knew it would save my body. It does not save time, not noticeably anyway. Will keep it 'just in case' Built well
dazzle
James
I hit play and I said a 750 PSI within the first 5 second
My apologies my volume was turned down when I hit play and missed the audio at the beginning.
Performer 405.
I am trying to figure out if I want a spinner, Jetted or if a Trinity as my next tool. My plan is to go after commercial
Performer 405.
In order to effectively use a super spinner, your truck mount needs to sustain 200° plus at 1,000 PSI..
Not many of them do that.
dazzle
James
Mine started out as a 405 but I have removed all heating components of the machine and added a lil giant so it might. Not sure if it will maintain 200 plus at 1000 psi but I guess I can set up a wand tile tool with similar flow and see how long it can maintain
Reactions: Mike Pailliotet
Highly recommend that you do so
I can proudly say my ThermalWave II does hold that kind of performance after my redesign of the heat exchanger. I'm proud of that Blue beast after all the work I've put in it
How long did it take you to get it done and redesigned?
It took only about a week for me to prepare it and get my welder to redesign the exhaust heat exchanger, and put it all back together, since I've been working in between all of it
That smaller exhaust pipe that’s mounted and welded on the back of that box originally was routed on top of that box, which bypassed heating the water. (Wasted energy). Now that it’s mounted in the box it does 3 things: delivers constant reliable heat over 220, reduced the machine’s temp since it’s mixed in with the blowers exhaust (was 700F on top of the box, now it is 300-350f), and the finned coils act as a muffler which the machine is quieter and smoother sounding.
The welds are rough but the design is great
att.U6PPkV9OmeF-GNZoUmDiJNaMPP6uwbZRk3mley49s7M.jpeg att.Etew_7IB3cw0o7zpBpx5zxIahdXKlKr4Q9tJaZICHQA.jpeg
