Best Solution Line
Swani
What is the best solution line these days? I'm not worried about cost. I just want something with the least amount of memory, doesn't bleed on the carpet, and can take high heat.
Friday I was doing a post construction clean at a historical building that was being remodeled and my line blew right at my QC on/off valve. I'm glad I wasn't using high heat because it sprayed me right in the face, which was still actually pretty dang hot.
Dwain Ray
I see ya got a wanders valve on that hose. My advice is, STAY AWAY FROM THEIR HOSES!!! Goodyear neptune 3000 has been my go to for decades
Reactions: Living The Dream
scotty747
30142 Carpet Cleaning Hose for Hot and Cold Water Use, 3000 PSI, 1/4 Inch by 100 Feet, Blue​
Bought this cheep hose on Amazon 4 years ago. Best hose I ever used. I bought 2 more for when it finally crapped out but its still going strong. had it cut down from 100 to 50.
Doug Cox
Doug Cox
I’ve never liked the weight of steel braided hose. The only other I ‘ve used is thermoplastic hose, so therefore super flex and parflex 1035ht are the only other hoses I’ve used. Parflex for the win, love it or hate it.
sassyotto
Paul
used Parflex which takes a long time to lose that fishing line coiling. Switched to Cobbs hose and like it better.
Hand coiled Parkers is my favorite..
I currently use that OEM hose blue in color and I believe Cobb's sold it at one point.. I bought it off amazon.. Decent hose for the price but it's grabby as in doesn't slide well..
Zero complaints so far
Westpak has sold it for decades with no chronic issues.
I've used it for years as long as your machine isn't a flame thrower, I get 2 years on avg, and then a small pin hole leak and I replace it.
Never had one explode like good year
Ps 100 ft for under a $100 on Amazon.
Same stuff Cobbs and bristor sold blue OEM.
It is a little stiff at first but when on use will relax.
You guys must be using piss warm water because my titan575 was too hot for that drinking straw of a hose. I went through several of them when I experimented with it. Waste of money
Not everyone’s a Matt.. 😁
I also used it on my #4LG heater..
Same with Parker.. OEM hose I use is 200’ hand coiled.. Not steelbraided, but I do use a 25’ leader line of Neptune off both my SteamGenie and #4LG heater..
YMMV
YMMV
4LG heater? I didn't know you were still living in the 80s!!! You old fart
  • Love
Reactions: Nate The Great
Bryce C
DFW
Bryce
I've got a few months use on my first solution hose on my first truckmount. In that time I've learned how to carry it and not smear driveway tar on it. I really like my solution line, it feels like the best solution line ever. I don't know what make it is.
I'll post an update in a few years when I have matured as a carpet cleaner.
Bryce C
DFW
Bryce
I just learned mine is made by Eagle Wash. Wow, this thing really must be the best solution hose ever. It's over $80k/foot 🫨 I'll need to pull out a loan when it's time to replace it.
sassyotto
Paul
one other reason I like Cobbs is because they custom cut the length for me. I have a continuous 120 foot solution line. That way in Wisconsin winters there is not quick connect outside to freeze so its never a problem even at Zero degrees.
jack zerkie
The ends were stainless on some not just steel
Swani
Any issues with bleeding on these? When is your upholstery tool going to be for sale?
no bleeding
Still perfecting the uph tool
Ive been using it a lot, and I realized just how much users will be cleaning with and without a Glide on (it works really good without in a lot of situations, so were beefing uo the internal inserts.
Waiting on a titanium beta head to test
Swani
no bleeding
Sounds good Mike. I'll be placing an order soon. Looking forward to the upholstery tool. I love my Drimaster but it's a pain to take apart and clean, and it's starting to leak water around the valve. I probably need to strip it completely down and rebuild.
Joseph Petrichor
Best? Parker parflex 50’s why? Less chance of marking up vinyl floors from heat transfer, and last decades with heavy high heat use.
John Gerding
John Gerding
Hydroforce Pro, the 4000 psi stuff from Aramsco. Why? Because I run a burner and this is the only hose that can handle the heat and not die in a month. It looks like it costs more but its way cheaper because you wont be replacing it every 6 months. I get a full season out of the 100 foot lead hose and typically 2 to 3 seasons out of the next few 50 foot sections. It never just bursts either, it will develop a pin hole usually very near one of the crimps, zero chance of black death either. I clean a lot of tile and the machine usually sits at 225 constant heat 800 to 1000 psi daily...Best hose there is... Goodyear is black death waiting to happen.
