Best Solution Line
Swani
What is the best solution line these days? I'm not worried about cost. I just want something with the least amount of memory, doesn't bleed on the carpet, and can take high heat.
Friday I was doing a post construction clean at a historical building that was being remodeled and my line blew right at my QC on/off valve. I'm glad I wasn't using high heat because it sprayed me right in the face, which was still actually pretty dang hot.
Dwain Ray
I see ya got a wanders valve on that hose. My advice is, STAY AWAY FROM THEIR HOSES!!! Goodyear neptune 3000 has been my go to for decades
Reactions: Living The Dream
scotty747
30142 Carpet Cleaning Hose for Hot and Cold Water Use, 3000 PSI, 1/4 Inch by 100 Feet, Blue​
Bought this cheep hose on Amazon 4 years ago. Best hose I ever used. I bought 2 more for when it finally crapped out but its still going strong. had it cut down from 100 to 50.
Doug Cox
Doug Cox
I’ve never liked the weight of steel braided hose. The only other I ‘ve used is thermoplastic hose, so therefore super flex and parflex 1035ht are the only other hoses I’ve used. Parflex for the win, love it or hate it.
sassyotto
Paul
used Parflex which takes a long time to lose that fishing line coiling. Switched to Cobbs hose and like it better.
Hand coiled Parkers is my favorite..
I currently use that OEM hose blue in color and I believe Cobb's sold it at one point.. I bought it off amazon.. Decent hose for the price but it's grabby as in doesn't slide well..
Zero complaints so far
Westpak has sold it for decades with no chronic issues.
I've used it for years as long as your machine isn't a flame thrower, I get 2 years on avg, and then a small pin hole leak and I replace it.
Never had one explode like good year
Ps 100 ft for under a $100 on Amazon.
Same stuff Cobbs and bristor sold blue OEM.
It is a little stiff at first but when on use will relax.
You guys must be using piss warm water because my titan575 was too hot for that drinking straw of a hose. I went through several of them when I experimented with it. Waste of money
Not everyone’s a Matt.. 😁
I also used it on my #4LG heater..
Same with Parker.. OEM hose I use is 200’ hand coiled.. Not steelbraided, but I do use a 25’ leader line of Neptune off both my SteamGenie and #4LG heater..
YMMV
YMMV
4LG heater? I didn't know you were still living in the 80s!!! You old fart
