Chemical Injection system?
royalkid
Gulf Coast Carpet Care
When I bought my used Butler, the chemical injection system didn't work. I don't use a lot of high pH pre-sprays, but am considering getting the system for my van. How many of you guys use it often and does it make a big difference? Worth spending $1,200 or not?
Thx!
Dwain Ray
Thx!
1200.00 is alot! You should be able to get everything necessary for well under 600.00 and maybe an extra 100 to go all stainless. You can get a great General Pump pulse pump for under 300.00. Youll need a check valve for soulition out i love epic 3/8 check valve about 90.00. Youll need 2-⅛" valves DONT SKIMP HERE! buy swagelok youll need 1-needle & 1-3way. About 150-200.00 for both a few assorted fittings (i strongly recommend stainless) a couple of small stainless braided teflon hoses anda couple hours install. You will have to drill and tap a valve cap on your pressure pump to install a pulse pump
Screenshot_20251121_135603_Google.jpg Screenshot_20251121_135840_eBay.jpg Screenshot_20251121_135846_eBay.jpg Screenshot_20251121_141143_eBay.jpg Screenshot_20251121_141450_Amazon Shopping.jpg Screenshot_20251121_141317_Google.jpg
  • Love
Reactions: royalkid
sassyotto
Paul
Ive been rinsing with just soft water for years. What I noticed is that when I go back the next time the carpet is cleaner and cleans better without using a rinse. I know, that goes against everything youve been told, but just what I see.
they live
Steve
Im a soft water user also and after replacing my injection system a couple times on my butler I learned it works as a siphon system when its broken. Sometimes it empties the 2 gallon jug in just a few jobs that way.
I only use odorcide in it though.
