Chemical Injection system?
royalkid
Gulf Coast Carpet Care
When I bought my used Butler, the chemical injection system didn't work. I don't use a lot of high pH pre-sprays, but am considering getting the system for my van. How many of you guys use it often and does it make a big difference? Worth spending $1,200 or not?
Thx!
Dwain Ray
Thx!
1200.00 is alot! You should be able to get everything necessary for well under 600.00 and maybe an extra 100 to go all stainless. You can get a great General Pump pulse pump for under 300.00. Youll need a check valve for soulition out i love epic 3/8 check valve about 90.00. Youll need 2-⅛" valves DONT SKIMP HERE! buy swagelok youll need 1-needle & 1-3way. About 150-200.00 for both a few assorted fittings (i strongly recommend stainless) a couple of small stainless braided teflon hoses anda couple hours install. You will have to drill and tap a valve cap on your pressure pump to install a pulse pump
Screenshot_20251121_135603_Google.jpg Screenshot_20251121_135840_eBay.jpg Screenshot_20251121_135846_eBay.jpg Screenshot_20251121_141143_eBay.jpg Screenshot_20251121_141450_Amazon Shopping.jpg Screenshot_20251121_141317_Google.jpg
sassyotto
Paul
Ive been rinsing with just soft water for years. What I noticed is that when I go back the next time the carpet is cleaner and cleans better without using a rinse. I know, that goes against everything youve been told, but just what I see.
they live
Steve
Im a soft water user also and after replacing my injection system a couple times on my butler I learned it works as a siphon system when its broken. Sometimes it empties the 2 gallon jug in just a few jobs that way.
I only use odorcide in it though.
Reactions: royalkid
Swani
@Cleanworks has really changed my mind on ph and rinse. Hopefully he will explain, but if PH is your main concern for running a rinse. Dirt and everything else plays a factor.
Reactions: royalkid
they live
Steve
All fiber rinse caused mold in my injection system. Its why I switched to odorcide. I figured if my rinse system could mold im spreading that to whatever im cleaning.
Im pretty confident that my rinse water is safe for the families I clean for.
royalkid
Ive done both for extended periods of time
an 4.5 All Fiber Rinse is the winner.
Do you use an injection system or post apply? And what % of jobs would you say you use a rinse on? Trying to determine if it's worth spending the $ to add to my butler or just grab a few gallons and post apply as needed. Thx!
Injection.
A chemical injection is needed. Do I use it on every job? no. It's not needed on every job. But when it is needed, it improves the success of your cleaning by double what you would normally expect.
Example: pet urine spots. I've learned that before you pull out the gallon bucket OSR dump method, or soak it in whatever magical liquid enzyme you have on the shelf, just turning up your acid rinse on a basic rinse first, treat after method, you can avoid doing those extra steps. Now, we all know if the carpet is saturated in urine, that the basic quick rinse first idea won't work. But on most of your maintained jobs that customers call yearly, this method helps your job efficiency improve dramatically
Or, you might need to add an odorcide product on a trashed apartment to leave behind a pleasant smell to kill the bong juice/smelly feet odor. The chemical pump/injector is a huge need on this.
But on tile and grout, or basic maintenance or even commercial carpet cleaning? Nah. YOu're just wasting chemicals on those jobs if you use a rinse product.
