What “flow” number meansEach jet has a flow rating (for example, a 02 jet is “2 flow,” a 015 jet is “1.5 flow,” a 03 jet is “3 flow,” etc.).To get the wand’s “flow,” you add up the flow numbers of all the jets on that wand.Example: two 02 jets → 2 + 2 = “4 flow.”Example: three 02 jets → 2 + 2 + 2 = “6 flow.”Flow is based on psi. Most spray jets are rated at 40psi. Based on that, 5 - 80015 jets will flow .75 gpm @40 psi (.15gpm per jet×5) and 1.35 to 1.5gpm @400psi
View attachment 133179 View attachment 133180
Am I wrong again?
