Solution line marks
Bryce C
DFW
Bryce
on light colored carpets really bother me. My Eaglewash solution line is the worst. I have a 125' Continental solution line that I now bring in on light colored carpets, but today I saw even it mark a very light nylon with it's wretched blue dye bleeding off under high heat.
What solution line can I buy that will never do this again? Are there any?
Also what do you guys do to remove the marks? I Often notice after I am all packed up and grooming the carpet. So I go back and forth with volatile solvent and distilled water lightly agitating it with terry cloths..
Reactions: Living The Dream
frank fratto
frank fratto
VLM after it may save your bacon🥓
  • Wow
Reactions: Bryce C
Reactions: Bryce C
Bryce C
DFW
Bryce
Goodyear hose has never left color lines on my carpet. It’s “non-marking hose”. What kind of water temperatures are you running?
That may be the winner, thanks. I'm running it as hot as I can with my coolant and salsa hx. I should really check the gauge again. Last time I checked was several months ago in the dead of winter and it was a bit over 200 at the machine. Can't recall how long it had been running either.
I used my PEX 500 for 1 job a week or so ago, I'm amazed at how hot the 2000 watt electric hx on that thing gets the water. My brass fitting on my wand feels the same on my truckmount as the PEX 500 when it's running a lot. A much shorter run, but still impressive.
Bryce C
DFW
Bryce
or Parker Parflex 1035HT if you dont care for braided hose
Are you talking about the difference between braided steel and thermoplastic?
Hose construction type doe sn't dictate color bleed, but Ive never seen or heard of Thermoplastics bleeding, or "my" SuperFlex stuff either.
Westpak has been selling it for decades with no abnormalities
Reactions: Bryce C
Im sure you can find a weeks worth of reading here on MB about the benefits of both.
I was a die hard 1035HT fan for a long time but my move to NV dictated (no one who could repair it) me having to change to braided, which took me a dozen jobs to get used too.
Reactions: Bryce C
frank fratto
frank fratto
Back when I ran a Vortex (Aerotech) unit I had 240 at the machine and sometimes would burn lines in carpet. Even then, my Goodyear hose never bled color onto the carpet, but I did learn to turn my heat down to 230 … which was still about 10 to 15 degrees past the point of diminishing returns.
Hoghowl,
Did you ever had to buy carpet because you melted it?
For me more then once😤
FredBoyle
Fred Boyle
Role
Cleaning Professional
Years of Experience
38
How aggressive is your cleaning pre spray?
Some solvents can remove the dye, especially if you are using high heat
Bryce C
DFW
Bryce
Good call, I never thought of that. In that home I was using Procyon Plus Powder boosted with peroxide. The strongest stuff I use these days is Procyon Extreme Carpet Prespray boosted with either peroxide or Benefect Atomic degreaser. My highest pH is 10.5 and there are no solvents in the prespray.
jeffexe
jeff
Hey No sharing the Benefect booster secrets
  • Wow
Reactions: Bryce C
Bryce C
DFW
Bryce
This is on hi at 1500 rpms full blast, and it is about 70 degrees outside. This is as hot as my system gets. Maybe a few degrees hotter in the summer.
There's nothing wrong with that. My heat is between 230-250 on a full throttle trashed carpet job, so you're in the sweet spot.
As for the blue lines. Just spray your hose in a pile on a concrete slab with your favorite carpet juice one day and rinse and wipe off the weak blue that keeps bleeding, and rinse your hose good. That'll help
Reactions: Bryce C and hogjowl
Bryce C
DFW
Bryce
Is it really a limited amount of free dye towards the outer layer? Have you noticed bleeding lines actually bleed less over time? I thought it would just be never ending as it has the dye throughout the material..
Bryce C
DFW
Bryce
So the owner of a cleaning supply store sold me my Eaglewash. He gave me the 150' run for $120 (heavily discounted from about $350 or so). To be clear this is a specific carpet cleaning supply and truckmount repair facility, this is what they do. And they even have a press to crimp the high pressure fittings on these solution lines...
I should call them and see if they still stock that brand. If they don't, I suspect he dumped the last of his bleeding junk solution line on the new guy...
I though
Eaglewash was bought out by another brand called flextral by Bridgestone but I checked and couldn’t find that relation anymore. I forget where I got that info. But JGB currently owns eaglewash so they’re still available.
But to answer your question , yes there is a point where it will stop bleeding.
  • Love
Reactions: Bryce C
Bryce C
DFW
Bryce
I though
Bryce C
DFW
Bryce
Well that is good to know. Maybe I will keep using it until it is naturally time to replace it. I'll follow your advice to clean it off myself and remove more of the dye too. Thank you!
