bob vawter said:Price the difference on draglinks..tierod ends...or even the price of brake parts are sky high...and if you take a one ton into a shop....
bend over!
Josh said:I rekin a 1/2 ton would be ok for a pto.
I have a smaller slide in and a 1/2 ton Chevy.
My next van will be a 3/4 ton.
Greenie said:damn Bob...you are a motor head, u sposed' to give good advice, not cheap advice.
1 ton stretch is the minimum a guy would want if he's gonna be in this gig for any amount of time.
bob vawter said:Come on Greenie...would i steer ya wrong?
Not once have i ever felt the need for a something bigger....than a half! First of all my Genie don't weigh 600 650lbs.......and i NEVER carry water...clean OR dirty.....half is perfect!
Able 1 said:I have a 3/4 ton and with full 120 gal. fw tank, full gas tank, me and eveything I use I was around 8000 pounds... I took it to a quarry to have it weighed. Haven't done a break job and I'm at 46,000mi.. I do drive like a grandpa though because I hate when the water sloshes around and knocks of the caps off my fw tanks. I really haven't had any problems with my van yet..
Larry Cobb said:Hi Jeff;
Welcome to the board.
You can work with a 3/4 ton van if you have a TM that is lighter than most.
If you want to carry 75-100 gallons of water, then a 1 ton is a better choice.
Gas economy is usually better on the 3/4 ton models.
What size fourwinns do you have ?
Larry
Carlson Ski Rig
