100% VLM ???
frank fratto
Cleaning Professional
frank fratto
Frank let me know if I missed anything
Advantages for using the VLM Method
1 - NO petroleum needed
2 - NO TM blasting away disturbing the neighbors
3 - NO TM emissions polluting the environment
4 - NO doors open or security issues
5 - NO doors open allowing cold air in or warm air out Winter or cold air out and warm air in Summer
6 - NO doors open allowing insects in ( Florida Snakes Alligators Lizards )
7 - NO doors open allowing cats-dogs to get out
8 - NO close parking issues
9 - NO dumping dirty water issues
10 - NO van doors open allowing rain snow to pour in
11 - NO van doors open inviting thieves
12 - NO long Dry Times
13 - NO vacuum solution hoses covered with mud snow rain when working in bad weather conditions
14 - NO long set ups dragging carrying vacuum solution hoses from van to house 300 ft - 400 ft of hose
15 - NO maintenance issues
16 - NO ridiculous priced TM
17 - NO ridiculous priced TM repairs
18 - NO ridiculous priced TM replacement parts
19 - NO worries of TM water pump or solution hose freezing on a job
20 - NO heaters needed at night to prevent TM freezing
21 - NO worries of TM breakdown on job or difficult repairs on job
22 - NO worries about wicking
23 - NO worries of dull dingy looking carpet after drying
24 - NO large lease or loan payments every month for TM
25 - NO low profits because of high business cost
Disadvantages for using the VLM Method
1 - It's slower on Medium and Heavily Soiled Carpet
I love VLM !!!
If you have an open mind, read this? 👆
Reactions: SteamwayPro
I have an open mind when it comes to commercial carpet. It's the ticket.😃This off white carpet tile
with coffee stains and trash dribbles all the way to the door came out nice with lmc. Wasn't even worth dragging a porty out🤷🏼‍♂️
frank fratto
frank fratto
View attachment 134548 View attachment 134549
What's the difference between a loop carpet or a 1/3 inch carpet thread or a 1 inch carpet thread?
Or a flat polish cotton thread, or a synthetic microfiber thread, or a wool texture weave thread
or a jacquard weave???
What's the difference can some please tell me??? When it comes to cleaning them???
Nothing really, but I'll let those who clean with BABIES crawling around answer that. I know even with cgd, daycares like to have hwe
done for peace of mind.
Reactions: frank fratto
frank fratto
frank fratto
The difference is in confidence either you have it or you don't.
Be it steam cleaning or VLM.
Confidence will determine if you can get it to come clean with either method?
We all know 90% of TM cleaners are doing one pass cleaning on 95% of the carpet in room? {Dwain this does not apply to you.}
That's because they know if they do more then 3 passes they become a MUD MAKER😳
Am i WRONG???
frank fratto
frank fratto
Funny!
When I was in Salt Lake City I cleaned for the largest and second largest day care.
They told me they preferred VLM cleaning "FROM ME" over TM cleaning.
It stay cleaner much longer after cleaning 🤔 🙂
I know that and you know that, but not everyone knows that. That had a nursery on both sides of it. I cleaned them with low moisture. They don't care, just clean it. It's a moot point with me. If I need to clean a rectory, which is a house, tm it will be.
frank fratto
frank fratto
So many downside for owning a TM.😤
So many upside for switching to VLM😀
Within 10 days, i could switch back to a TM,
knowing what I know now there's no way I wound do that. I just wished I did it 30 years sooner. "VLM"
I'm glad I've owned TM's for a long period's of time.
That way I can compare the DIFFERENCE!!!
I've owned Bane-Clene small and medium TM and yes 2 fire breathing dragons TM!!!
It don't apply to me either since I use a crb either way. I also use renovators. Where does the dirt go? I do take em off to get in corners!
frank fratto
frank fratto
I,
mostly Pad Cap.
Where does all the dirt go???
I don't know,??? but I do know wherever it goes, it stays there and it doesn't come back on top of the carpet.
unlike most MUD MAKERS, their carpet re- soil with in 1 week 😳
frank fratto
frank fratto
Can we stop with the MUD Makers references. It is rather juvenile .
For years, I heard you guys tell me VLM didn't work on 1 inch residential carpet?
And if you didn't have a 9.3 blower, you wasn't getting carpet clean 🤔 [go back on every thread that talks about VLM tell me that's not so?]
So I thought I would tell you all it isn't the method it's the person doing the cleaning.
TM works, but so does VLM!
And if you're a MUD MAKER, so be it🙂
jeffexe
jeff
So Spiteful and Juvenile.
The same with my renovators on a crb, we know they can dig dirt and debris, but c'mon🤷🏼‍♂️😉
SteamwayPro
George
I,
mostly Pad Cap.
VLM uses agitation
The dirt gets removed extracted absorbed into bonnets and then goes into my Dirty Water Tank ( Washing Machine )
What doesn't go into the bonnets and is left behind is encapsulated in the detergent and crystallizes
It's a simple easy COMMON SENSE approach for cleaning carpet
TM's use many many more gallons of water and uses WATER PRESSURE
After the wand passes over the carpet whatever is left behind is dirty water
The carpet might look clean but if it takes 3-5-7 hours to dry that's all dirty water and dirt left behind
What happens to the dirt left behind ???
For the Owner Operators that don't like MONEY keep on using a TM
Owner Operators with COMMON SENSE that like MONEY and HUGE Profits will use VLM
LESS water MORE agitation !!!
Dwain Ray
"What doesn't go into the bonnets and is left behind is encapsulated in the detergent and crystallizes."THIS IS RESIDUE! I believe in agitation thats why i clean with an rx20 but where you are loosening me is RESIDUE. after cleaning with an rx20 i go back and rinse and dry the carpet again with a drag wand and because I thoroughly clean and dry the carpet before i rinse and dry it i dont see any of the "leftover dirt" you speak of coming up the long clear viewing tube of the drag wand, and because i leave the carpet cleaned/rinsed/dried theres certainly absolutely no "ENCAPSULATED, CRYSTALLIZED DETERGENT " or anything else for that matters ever "left behind"
20200103_133310.jpg 20200103_133537.jpg 20200103_133624.jpg 20200103_134147.jpg 20200103_143724.jpg 20200103_143803.jpg 20200103_144418.jpg
frank fratto
frank fratto
"What doesn't go into the bonnets and is left behind is encapsulated in the detergent and crystallizes." IS RESIDUE! I believe in agitation thats why i clean with an rx20 but where you are loosening me is RESIDUE. after cleaning with an rx20 i go back and rimse and dry the carpet again with a drag wand and because I thoroughly clean the carpet i dont see any dirt coming up the long clear viewing tube of the drag wand and because i leave the carpet cleaned/rinsed/dried theres certainly absolutely no "ENCAPSULATED, CRYSTALLIZED DETERGENT " or anything else for that matters ever "left behind"
View attachment 134565 View attachment 134566 View attachment 134567 View attachment 134568 View attachment 134569 View attachment 134570 View attachment 134571
I can take a 175, a few chemicals. Mine happened to be low ph.
One red pad and one baby blue microfiber pad.
And get those exact same results that you did in your pictures.
For whatever reason I don't kown?
I am convinced the carpet stays cleaner for a much longer period of time.
That's why I will never switch back to a TM of any kind, be a used $3000 TM.
Or a new $110,000 TM.
Why on God's green earth would I want to put myself through TM misery, day in and day out.
EXAMPLE?
Relieving pressure from my solution holes at the quick connect.{This is something I don't worry about anymore.}
Dwain Ray
EXAMPLE?
You may get the same looking results. But as directly quoted from previous statements "WHAT DOESN'T GO INTO THE BONNETS AND IS LEFT BEHIND IS ENCAPSULATED IN DETERGENT AND CRYSTALLIZES " that quote is verbatim! HOW DO YOU SPELL RESIDUE? I spell it ENCAPSULATED
frank fratto
frank fratto
Been doing this method for 10 years now full-time I've not had one call back from residue. NOT ONE.....
Dwain Ray
But you do leave residue? Correct? If not how do you remove all the residue? According to the statement i quoted suggests that residue remains regardless of whether or not you're called back on it.
frank fratto
frank fratto
All methods leave residue,
I've just never had a problem with it.
I can get it clean, keep it looking cleaner much longer with VLM, that makes my customers HAPPIER,
and I don't need all the downside of a TM to do it [ I consider that a very BIG WIN!!!]
frank fratto
frank fratto
jeff,
Please explain?
Sticks and stones may break your bones? [not from me]
My words should never hurt you.
I'm just here to debate and discuss maybe educate?
So if I've said anything wrong, please call me out on the the Carpet.
I will gladly Apologize and retract any wrong statement 🙂
SteamwayPro
George
Yes I know the GROUP THINK Members here HATE VLM talk and Me
Don't let your Blood Pressure rise
Just ignore this thread !!!
Frank I warned them in the very beginning
If they get their feelings hurt easily because some cleaners have a different opinion on cleaning carpet they shouldn't come into this thread
They should stay in their SAFE SPACE avoid of VLM Talk
Most of what we are saying is just our opinion but some of what we are saying is FACTS and some cleaners just can't accept the fact that maybe there is ANOTHER Way, a BETTER Way, a SIMPLIER Way, and a MORE Profitable Way to clean carpet in 2026
Number One advantage on my 25 advantages for using the VLM Method is NO Petroleum
That is a FACT and I'm glad I don't have a TM blasting away outside disturbing the neighbors POLLUTING the Environment and DRAINING my Wallet
Cleaners that don't like MONEY are WASTING so much MONEY on gas but don't want to hear the TRUTH or FACTS about VLM
I love VLM !!!
You do get carried away with #facts. Almost everyone here agrees that vlm is a good way to clean. Most have the tools, period.
  • Eyeroll
SteamwayPro
George
Other than me and Frank I don't know anyone here that thinks VLM is good way to clean Residential
