Out of Character - 0
I just recently realized that 2 of our machines have 2000psi heat exchangers and we've never run them past 1000. Since we've been running higher pressures on t&g our pro2000 has eaten 2 clutches (soon to be 3) in less than 500hrs. The clutch isn't strong enough to spin two roots 45's @ 15hg and go past 1200psi. I'm not wanting to reduce the hg's if we don't have to.
What is the strongest 2 groove clutch I can get on the front of our white magic shaft?
Thank you.
Thank you.
