Chris Muetterties
- Joined
- Oct 8, 2006
- Messages
- 1,652
I was noticing that my air flow on my A/C-Heater was getting worse. Right under the fuse block center dash is a cover with 4 screws and then you have to remove 2 screws on the fuse block and let it hang. Thats when we found 2 screw in the front of the heater assembly (not the fan housing). Those 2 screws are the screen filter that was about 90% clogged.
Wow we are back to full cooling and heat !!
