Marty said:Seriously ... you find a need for 5 inch tabs often enough to buy some?
I have never had any ... but was sitting here trying to imagine when I might need them ... and can't.
KevinD said:Marty said:Seriously ... you find a need for 5 inch tabs often enough to buy some?
If you ever bent over and moved a piece of furniture you might find a use for them.
Dave Yoakum said:Have a 1/4 sheet of builder sytrofoam on the truck and I just cut larger blocks if needed,
I agree if a leg is that big it needs a block or/and ventilation.
Becker said:Dave Yoakum said:Have a 1/4 sheet of builder sytrofoam on the truck and I just cut larger blocks if needed,
You carry bulk foam and cut as you go?
rhino1 said:L shape may need 2 blocks on each leg. You can carry a roll of Satan wrap or wax paper also. I don't get carrying Styrofoam and sawing blocks to size, just use more blocks.
Marty said:No hair piece here ... buz cut. Anyway, back to the point, I understand the use of degrading humor to deflect the conversation away from an area you may be unable to argue, and it was funny to boot, but my point is that usually when the leg or contact point of a piece of furniture is large enough to need a 5 inch tab, it is usually heavy enough that using a block is faster and easier on your back ... even when using a lift buddy. (If you don't have a lift buddy, get one.) I think this may be the reason you are having a hard time finding a source for 5 inch tabs.
Doc Holliday said:![]()
On you or me.........I can't speak Spanish so I'm pretty sure I'll be in big trouble! :mrgreen:
Hoody said:Marty said:No hair piece here ... buz cut. Anyway, back to the point, I understand the use of degrading humor to deflect the conversation away from an area you may be unable to argue, and it was funny to boot, but my point is that usually when the leg or contact point of a piece of furniture is large enough to need a 5 inch tab, it is usually heavy enough that using a block is faster and easier on your back ... even when using a lift buddy. (If you don't have a lift buddy, get one.) I think this may be the reason you are having a hard time finding a source for 5 inch tabs.
Its hard to take you seriously and I hate admitting when you're right, but I do agree.
I thought "bueno" meant "good"?"bueno?"
Yep there are plenty of other reasons to hate him!Don't hate me cuz I am smart, Hoodie.
Willy P said:Stickys stick together really well.....make them in the size you need :roll:
