Padden McFadden
- Joined
- Dec 21, 2006
- Messages
- 352
I had to see if the hype was true, so got some powermax and dynacide to try out.
Some questions come to mind,
the evening sun has the inside van temp in the 120 degree range, Will leaving the powermax in that kind of heat hurt the enzyme or weeken it in any way?
Also was wondering what the shelf life of the RTU mix would be?
On the dynacide lable it says do not mix with other chems. I was hoping I could ad a few onces to the powermax pre spray for a deoderizer boost. Will that be OK?
( I'm just used to using odorcide, and dd12 this way)
I've tried powermax on 2 jobs Saturday, worked great , so the hype is true. 4 oz per gallon seems to really kick butt, killed urine stains and nuked the dirt.
