X
XTREME1
I thought Ricky was joking when he said the thing was good. It isn't an apex but it is a very suitable portable/truckmount with some more heat it would rival the avenger I was riding before
Brian Luddy said:Schwing!
It didn't take Ricky long to put Crowley's post on the Recoil Board.
Matt Murdock said:where is the cross american board[/quote
http://www.ocibr.com/hub/
Read the post where Rickie says he charges customers for furniture tabs and tells them to saran wrap the furniture legs before he shows up to save money. Then another guy say he cuts his own tabs from tin foil. Some quality stuff over there. :roll:
Mikey P said:I hear we will have a brand new unit to test at MF.
meAt said:Mikey P said:I hear we will have a brand new unit to test at MF.
please don't try to make the tests some kind "rocket science", overly complicated scientific endeavor
Keep it simple and practical
same hose, same sol line, same wand, same "operator" (that's important) doing his/her best to use exactly the same speed/wand technique for the same amount of time with the different portys set at same PSI.
Each test should be run on a dry section of same carpet.
Measured amount of water in the porty, measure amount recovered
how fookin simple is that?
Once you establish which porty recovers the best (I doubt there will be a whole lot of difference in any of them :shock: )
Then you can move on to the different wand styles available and if there's really much difference in recovery on them.
Then unglided, and different glide versions recovery rates
using a porty makes things easier cause you can easily measure amounts of water in and water recovered
I wish the left coast wasn't so damn far away, making flying the only realistic option for me to attend.
or I'd do the tests for you ....RIGHT!
Limit the variables as much as possible for a fair impartial test
ie.. SAME hose, sol line, wand, psi, AND operator on dry sections of SAME carpet
Brett said:I would use one portable for solution line to eliminate any pump differences in other machines. Maybe you were going to do that anyway. 250psi and 400-450psi dry times might be fun to see. I have the Mytee 1003 2 3 stage 0-450 pump with heat, 1 1/2 hose port, and a new Recoil XPS 2" with the 0-500 pump which I don't run past 450. I have run 100FT 2" to 15 FT 1 1/2 and had reasonable dry times with the Recoil .Thats with AW29 1 1/2 wand and Green Hole glide. Suction is alot better with 50-75FT of 2" straight to wand. I can feel the lock down difference. I've only run 50FT with the Mytee, but dry times are OK. 200 degrees in the Mytee gets me 130 at the jets. Thats starting with 137 degrees out of my water heater and waiting about 15-20 minutes with heaters kicked on. Most customers homes I kick off the heaters and clean without them so I won't kick breakers. 20amps with pump,vac and heater and 19 amps other cord. Amp suckers. Remember, most homes have 20 amp breakers and 12-2 wiring in the kitchen, baths, garage and furnace closets,but they only have 15 amp plugs. As far as I have heard, residential appliances can't be sold over 13 amps so not much need for 20 amp plugs except for those of us running commercial machines in residential. I would not buy another heated machine. Buy seperate heater. Save the weight, if it breaks you can still use your porty, you can ship a small electric in for repairs, and more room inside machine for easier repairs.
Todd Anthony said:Does anyone know if the steamin demon is going to be at the shootout ?
if i was in the market for a portable i would consider the steamin demon .
less set up and no bucket brigade . plus the vac is only 6 inches from the carpet
makes sense to me on paper but i havent tried one .
John LaBarbera said:Is it you don't like to fly?
John
Mikey P said:just tie one on meAt, I'll drive your drunk ass from the airport.
meAt said:Mikey P said:just tie one on meAt, I'll drive your drunk ass from the airport.
buy me a "first class" plane ticket (round trip and HAS to be a window seat) and i might consider finding enough Valium or Xanax to medicate myself.
Then I "might" think about it
otherwise foggetaboutit....cause even a free coach class ticket, free room and board and get to drive around Lisa's new cool car all week wouldn't do it...
