A rotary
Meter Maid
The Undetective
Chris
Digs weird stuff out of carpet.
Not sure anything else can compare.
The carpet is only 1/4"-1/2" thick. If your wand can't get out the funk, you're doing something wrong.
Turn up the psi to 600-650 and bump it up to 10-12flow. I think rotaries are a waste of money
Andy
Doesn't Matter
They worth the money as you get older. And you will continue to do a consistent job throughout the day.
KevinD
Kevin Dumas
If you can't dig it out with a rotary you can always grind it back in further so it's not noticeable.
