bob vawter
Grassy Knoller
j]http://www.youtube.com/watch?v=rzPUZwev7V8j]
Goomer said:Other than loosing the benefit to the life of a radiator fan, and idling cooler, any other negative effects of running a SG without a heat exchanger?
John Olson" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">John Olson said:Ok so is it coming here or what?
kippy newberg said:there ARE no negative effects of running a SG without a heat exchanger....
well other than you will have no heated water!
Goomer said:kippy newberg said:there ARE no negative effects of running a SG without a heat exchanger....
Just wondering if a SG could be a potential contender for when I am ready to crank it up a notch.
Of course I would keep and utilize my fire breathing diesel-kero heater.
I'm sure the install would be a lot easier without having to install the heat exchanger also.
kippy newberg said:[quote="John Olson":3uiwn9dn]Ok so is it coming here or what?
kippy newberg said:shall i whittle together another frame for ya?
kippy newberg said:p]http://www.youtube.com/watch?v=rzPUZwev7V8p]
