and who in the hell thought putting a baptism pool heater in a van would be a good idea?
This has been used in our shop everyday since the 70s. We replaced the coil once and a few thermocouples over the years. Pretty solid unit. Tankless water heaters are basically the same concept.
Speaking of Juans...
Tim Yeater
The baptism Lt baby burners are absolutely archaic held together with sheet metal screws pray er and wishes There's no safety system to be derived
Do they work Yep they work Are they dangerous As dangerous as a honey enema at a beekeeper's convention
Sure it could be done safely but why
  • Haha
hyperbolize much?
Reactions: FB19087
Absolutely wrong. You have several safety systems from the thermocouple that stops the gas from flowing if the pilot goes out. The temperature control that regulates when the burner comes on and goes off. The pressure relief valve that opens at a preset pressure incase the heater starts to over heat. They are simple systems that have been found to be reliable for many years as long as idiots don't tinker with them
Say what you want....by all description
You are driving around in a fricking
Bomb!!!
Sometimes HE may leak...but in
My 40 some years using them they only swell up when frozen..... never
"Blow up" !
"Blow up" !
I've never seen or heard of a little giant or the tank actually blowing up..............a bit of a boom when lighting one improperly or one that is poorly maintained (had this happen myself)
and did you click the link and see Albert's HE? Looks like a cigar in old toons. THAT is "blowing up"
Fred...Fred......Fred.....! Why?
Bomb!!!
Not even close. Turn off the tank and you're golden. They can withstand higher impacts than your vehicle. Get hit hard enough to rupture the tank, you're probably already dead.
Sometimes a gravel road will jiggle
A Compression joint loose.....
'Cides that how many pics of burning houses do you need to see!
Haven't seen many pictures of burning houses caused by propane carpet cleaning heaters. Your responsibility to test your equipment to make sure it's not leaking. I always had a bottle of dish detergent in the truck.
Reactions: Sierra Clean Care
Jeff T
When I was a foolish teen, I took a pair of full 20lb cylinders out to the gravel quarry with a couple friends.
We had a 223 caliber AK47….
I unloaded it into both tanks, and all it did was hiss out propane…
We were expecting a BIG boom, but, nada…
I watched 250 gallon (?) tank pop off next to a burning trailer...........shot a flame higher than the trees for a while and made a cool noise but no boom (although I suppose it could have)
The tanks rarely explode. Most explosions occur when propane leaks into an enclosed area and a spark happens don't clean with your doors closed.
  • Eyeroll
Reactions: bob vawter
Jim Williams
Jim Williams
There was that one incident where the fitting rusted out and broke off on the pipe carrying propane to the gas valve on Waldo's LG and created a pretty good fire inside his box truck.
I have never actually heard of a tank exploding. You need the right proportion of has and air to create an explosion. Unless someone tampered with the pressure relief, I'm not sure it's even possible.
