ACE
This a "did I do that?" Type post. We refinished around 1000 sq ft of VCT on a concrete subfloor last night. I used Zep brand striper and mixed it strong 1:1. I had not used that label for a long time and did not bother reading the instructions (maximum recommended Dilution is 1:3). I just mixed it strong because there was heavy buildup and I did not want to strip twice. I did not notice the damage until I was putting down the second coat of sealer. There was what looked like warts randomly grouped in a couple of areas. I have defiantly seen this type of damage before but never thought much about what caused it. The blisters where flexible to the touch. The odd thing is that the damage only happened in areas that probably had water damage /moisture issues in the past ( near a utility room and in a bathroom). I tried searching online and read that this type of damage could be caused by high ph chemicals in the concrete reacting to the adhesive. Anyone seen this happen with a strip job before?
