On the chart - "URAI Blower Performance"
http://www.dresserroots.com/documents/UR...-12k84.pdf
How do I know how much HP a blower needs to run a pump and an engine. I'm not talking about a 45 blower, but just in general. How does someone come up w/ the math to determine how many HP's a certain system requires?
On the chart for a 45 blower for example it says:
3600 RPM's - @ 7 Psi - it'll do 369 cfm's & require a 14 HP, is the 14 HP a bare minimum? For the 11 Psi it says it requires 19.8 HP. Since I have a 18 HP I'm just trying to understand how all these things work.
Does the BHP/HP references the HP # of an engine only?
Also, if a larger blower is running @ 1760 RPM's while producing more CFM's than a blower running @ max vac @ 3600 RPM's, will the one at the lower RPM's put less wear on the engine, and also consume less gas?
Thx,
Bill
Thx,
Bill
