Bouncing CRB
BradFenstermaker
Looking to pick a CRB used from friend.
It kinda bounces as you use it. Only experience is cgd with heavy wear.
Blue brushes where the worst.
Black was much better.
Is it just flat spots on brushes from cradle??
Onfire_02_01
Jeremy Gray
Bouncing almost always means a flat spot on the brushes. Try running them under hot water to see if that will reset the bristles to their original straightness. Time may also help a little.
Don't let the crib set on this bristles, the cause of flat spots. Always replace back on the included base or tip onto its side or back when you are pausing for a bit.
I was thinking it was more than five words so he didn't read it.
Flat spots on the brushes would have been enough!
