Jon;
This is what we strive for with our TM's:
1.
Maximum Lift at the wand:
#4MR Blower @ 17" hg.
Minimum Restriction of Stainless Silencer
Open Recovery Tank with no baffle restriction
Gates 3VX Belt System with Dodge Sheaves
2.
Corrosion free Construction:-
Aircraft Aluminum Tank Construction (100 Gal + 75 Gal)
Stainless Pipe Fittings to Heat Exchanger
Stainless Engine Exhaust for Durable Insulation to HX
Stainless Bolts and Locknuts for Ease of Maintenance
3.
General Pump System with Teflon Packings for Unmatched Durability
Adjustable Front-Mounted Regulator for Carpet & Grout
Quick Setup for Flood Operation
4.
All-Stainless 40" Heat Exchanger which utilizes Engine and Blower Exhaust
for 230 degree heat without water bypass
Working Pressure of 1500 PSI for T & G work
5.
Kohler 34 HP Engine with reliability designed in . . .
Extended Service Intervals of 200 hours with H.D. Air Filter & Synthetic Oil
Oil Cooler Built-In
Operates @ 2700 RPM for Gas Saving (Single Wand)
6.
Now Comes with Electric Dual Reel Standard;
Bentley 2" Carbon Fiber Wand w/Teflon
Glide
SuperFlex 2" Vac Hose (150')
Parker 1035HT Solution Hose (150')
Compare the Details & Unmatched Value
What's not to Like !
http://www4.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=66&products_id=1269
Larry
