"Advice is a form of nostalgia, dispensing it is a way of
fishing the past from the disposal, wiping it off, painting over the
ugly parts and recycling it for more than
it’s worth."
Heres my advice...
Buy a book called The "E" Myth, learn what it means to be a business owner. Its more than just cleaning carpet. Write a business plan and marketing plan. You are starting a business with no experience, odds are that you will fail unless you add structure to what your doing. Lay the foundation with your business and marketing plan on how you are going to operate, what your cleaning process is and so on.
This job is mostly customer service, so you have to look the part and be fully uniformed & clean shaven. Effective communication is something you must do in order to prevent cleaning and customer issues. Dont make their problem your problem. Be up front and honest with everything you do and assume there is a nanny cam in every room.. everytime. If you are doing residential cleaning, your target market has many concerns before they choose you, unless referred. Many can be eliminated prior to contact if you have done a good job at selling yourself through your website and marketing.
Cleaning is easy..
Just prevacuum the carpet, it gets 60-80% of the soil out.. skipping this step could cause issues in some cases. It also adds value to your product.. carpet cleaning. The more value you offer, the more likely they will choose you over the other guys with little value.
Go to the search option above and start learning about the different products you can use to clean with. After you determine that... you pretreat the carpets after they are vacuumed.. some stains might need different products depending on what it is. Which you must learn before you do something that will cost you big time$$$.
Extract with your TM..
Groom the carpets, it helps with dry times and it also makes the carpet look better. First impressions are very important so get it looking its best.
Use airmovers if you can.
Practice safty too. Use corner guards, drop cloths for hardwoods, stair strap, yellow cones for your van and hoses.
Jon Don sales bright safty signs you can leave on all hard surfaces to remind the customer of the slipping hazards. They are $24 for 1000 sheets.. A MUST HAVE.
Keep your van clean as possible, you are not only selling carpet cleaning you are selling an image.. one that you have to get people to like in order for them to use you.
I would PM Harper and chat with him, he would be a great resource for you, along with many here.
Good Luck..
