getdusty
What exactly is a "carpet sanitizer" that I see some carpet cleaners offer?
Thanks!
Dusty
Thanks!
Dusty
As I was taught in iicrc or what ever it is calling its self now courses, to sanitize merely means to bring a surface to an acceptable level of cleanliness usualy eliminating around 70% of bacteria. I don understand how a disinfectant can have a range that begins at 100% when ha would mean sterill. I dont think we as on site cleaners have the ability to achieve that or even 99% without having a totaly controlled cleaning environmentShawn Forsythe said:To legally "sanitize" any surface, the reduction results must show a bacterial reduction of at least 99.9% over the parallel control count within 5 minutes. http://www.epa.gov/oppad001/dis_tss_docs/dis-10.htm
Here we have Carpet Sanitizers mentioned specifically: http://www.epa.gov/oppad001/dis_tss_docs/dis-08.htm
Many people correctly assume that it is a lower threshold than disinfection and the even more stringent classification, sterilization, and they are right. But that low threshold for "sanitize" is a lot higher than people think.
"Disinfectants" range from efficacy requirement of 100% down to 99.999%, depending on branded use. Whether disinfectants for Use in Hospital or Medical Environments versus General Broad-Spectrum Disinfectants, versus Disinfectants with stated Limited Efficacy. Sterilants are 100% efficacy in I think all applications for which efficacy is reasoned.
To legally "sanitize" a porous surface like carpet is no small undertaking. First you have to have an EPA registered method, and requisite chemical, if such method calls for one. Second, the method must be performed only in the manner that has been registered. You can't use any disinfectant/sanitizer/sterilant, and certainly not one inconsistent with its labeling. You will find only a small subset of "sanitizers" chemical agents will have any porous surfaces listed, and scant few have carpet as one of them.
sweendogg said:And for you Californians
http://www.prorestoreproducts.com/Conte ... x?cid=1191
still will sanitize per label directions and epa registered. At least I can't find it on the band list of products
Brian H said:How about just saying you will be applying a disinfectant or sanitizer to the carpet? Then there is no claim about disinfecting or sanitizing!!
sweendogg said:Shaun extended label:
Special instructions For Cleaning / Sanitizing Carpet Against Odor Causing Bacteria: Use this product in industrial and institutional areas such as
the manufacturer of the cleaning equipment. After using the product, set the carpet pile and protect the carpet from furniture legs and bases while drying.
Do not over-wet. If applied to stain resistant nylon carpet, apply a fabric protector according to the manufacturer’s directions
While you can't claim to kill virusus or fungicides.. it is more than just a use for water damage loss.
