Category 1 and VCT..
Ivan Turner
Ivan Turner
It depends. If the VCT has already separated, I'd opt for removal. However, as a rule I would dry first and then make an assessment on to remove, or not to remove.
We wouldn't remove VCT unless it needed to be removed.
Removed only if there were water beneath it or if it were bubbled or if it were over a wood or particle subfloor. Otherwise we would just monitor any seams for puckers or curling.
If it got to the slab then yes it should probably get pulled.
But if its down tight there is not much chance of it getting to the concrete.
How would u know? Just monitor
Yes monitor it.
It would need a path to get to the concrete. Around plumbing, HVAC vents, behind built-in's or at seams. I'd concentrate your drying there if any of those are in the affected area.
Make sure your lines of communication are clear with both the homeowner and adjuster. You didn't miss it, their is potential there but not enough to justify removal at this point. You'll keep an eye on it and inform them if there is any change needed.
Reactions: Ivan Turner
So what happens if the slab is wet? Concrete won't swell and expand or otherwise be damaged by moisture. The real problem with wet concrete is that the flooring adhesive might not stick to it. It the adhesive is turning loose, then worry if the VCT must be replaced (monitor). Normal drying process will get the moisture out of the slab in a few days.
You can get some microbial activity depending on what organic material might be present. We've seen some very high counts when moisture is trapped by the vinyl. It can also cause some discoloration from the microbial growth that would cause the damage.
Definitely happens, but I think you will have several days to get the slab dry before you have to worry about that. Concrete under VCT dries easier than under sheet vinyl since there is some space between tiles.
You are right the tile edges give you more surface to evaporate from.
Greg Cole
Greg
we have actually played with using wood floor mats to get VCT to re-adhere. 100% success rate. Granted only tried 4 times.
Reactions: J Scott W
My initial post were about vinyl, I read VCT but thought vinyl.
You might be able to use a tramex and go to an unaffected are and use it as your dry standard. The problem is concrete always have some moisture moiving though it so your meter could just pegged even in unaffected areas.
Wow that's impressive. We've never attempted it. We will dry a day and monitor from there unless you see water weeping from the edge or see it seep out when stepped on. Then its pull the loose tiles.
Greg Cole
Greg
Do it! It's pretty cool. The trick was to but all the mats together. Don't leave gaps like you would on wood floors.
Hoody
Steven Hoodlebrink
Years of Experience
20
Greg beat me to it... I had success twice with the same thing. Hook them up to your extractor/TM to get the majority of the water out first and let them extract for a little bit. Then hook them up to your dry force machine(s) to complete drying.
