CERTIFIED PILE LIFTER.....
P
pitmaster
I'm thinking about buying one good or bad choice :?:
P.O.S and a huge waste of money.......but I got one in brand new condition if you are interested.........If someone was to buy the Vortex I was going to pitch the thing in the back of the truck to get it out of here............
P
pitmaster
Thanks for the reply Jim can you explain why you think it a P.O.S :?:
Jeremy
Jeremy
They aren't the greatest vacuums but they do dig up a bunch of crud. So, if you do decide to pick one up, remember to vacuum after using it. One thing they are pretty good for (other than excavating dry crud & pet hair fom the pile) is scrubbing prespray... Just unplug the vac motor before you do it...
its a boat anchor..the thing weighs a ton...they don't vacuum worth a shit........they do help stand up the pile but for a lot less money you can get a good vacuum that does that... and it will vacuum stuff up...over rated..over priced...and worth less.........
I have a certified pile lifter sitting in the shed .... cost me around $1200.00......
$250.00 plus shipping.........used less the 12 times.......
Jeremy
Jeremy
Sounds like a sweet deal for someone... Want me to list it on the EncapStore?
I concur with my esteemed colleague, Mr Martin's findings
pee ess...if you do buy one, Certified is the best
There's one out there with a Chemspec label
It's more useless than the Cert brand
Buy Jims
..l.T.A.
steve r
for beaten down cgd traffic lanes the pile lifter does wonders. but i dont use mine much neither.
I agree with Jim and Larry.
As far as doing much to the carpet, it is worthless.
Impresses the clients a lot though.
If you buy it, just bring it in. No need to plug it in, just leave in a strategic visible place as to impress the hack out of your client.
Much better use than a boat anchor Jim!
joe harper
joe harper
Jim..
With you "engineering"...talents...!!!
Why don't you "tinker with the IDEA of removing the cloth bag...& convert it
to a "pool Filter"... :?: Could part of the vac problem be that the BAG...restricts
the air-flow... :?:
I bet you could "TWEEK"...the design & make this unit perform to PERFECTION... 8)
I have found that the SAND TRAP...is a poor design...loosing MASSIVE amounts of
suction or LIFT... :roll:
jus SaYin
The Certified pile lifter is a fantastic machine that will last forever. The problem that many people have is that they bought one to use as a heavy duty vacuum cleaner, but it's a pile lifter. Says so in big letters embossed right into the metal housing. The vacuum capablity is only meant to remove loose debris, such as shedding wool.
Every rug shop should have one, but I'm not sure a carpet cleaner needs one unless you do nap correction work for carpet mills.
If you need one, buy Jim's before it gets away. I'd buy it but we already have three, all of which are running strong after over twenty years of semi-daily use.
joe harper
joe harper
Jim...
I will take it....!!!!
Let me KNOW how you want payed...CASH,CHECK, or CC...
Check on freight & add it to the price....!
If you will accept CC....I will pre-pay..IN FULL...!!!!
Ship to : 33024 State Rd 52
San Antonio, Fl. 33576
Contact me @ 352-588-2499..........For cc #
Thanx
HARPER
Jim...
Thanx
HARPER
Sorry Harper...I already got a fish on the line.....If for some reason I cant land it I will let you know...............
joe harper
joe harper
Jim Martin said:
HARPER said:
[quote="Jim Martin":3ned8y4m]I have a certified pile lifter sitting in the shed .... cost me around $1200.00......
sorry Harper.I already got a fish on the line...but if for some reason I can't land it I will let you know..........
Jim...
Thanx
HARPER
[/quote:3ned8y4m]
10/4....
