Feb 6, 2013 #1 A Aaabrightfloor Member Joined Sep 7, 2012 Messages 142 Location Tampa bay Name Joe where can i buy a CFM Vacuum Gauge/Lift Vacuum Gauge?
Feb 6, 2013 #2 Able 1 Member Joined Apr 12, 2008 Messages 6,469 Location Wi Name Keith Not sure on the quality, but this might work? http://www.sears.com/shc/s/p_10153_...0P&srccode=cii_17588969&cpncode=31-77095441-2
Feb 6, 2013 #3 Shane T Member Joined Nov 7, 2006 Messages 1,663 Location Waukesha, WI Name Shane Tiegs There two different things. You can get a vac gauge at any auto parts store. CFM measures air volume, which one are you looking for.
Feb 7, 2013 #4 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb Joe; An accurate digital vac lift gauge is all you need: http://www4.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=68&products_id=3960 Larry
Feb 7, 2013 #5 A Aaabrightfloor Member Joined Sep 7, 2012 Messages 142 Location Tampa bay Name Joe Larry Cobb said: Joe; An accurate digital vac lift gauge is all you need: http://www4.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=68&products_id=3960 Larry Click to expand... Larry How about CFM? In some cases when you make changes on your system one goes up and not the other righ? How does it works?
Feb 9, 2013 #6 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb Joe; If you measure the lift accurately right at the wand . . . then CFM will be roughly proportional to the lift generated. IE, an increase of lift at the wand will signify an increase in CFM. Larry
