Why Chem-Dry?
Not steam cleaning! We are much better, Dry in less than 2 hours, using the best equiptment which holds the gold seal in cleaning. We are proud to say that the normal steam cleaning methods are a thing of the past, much healthier for the environment, your homes, and family.
This process extracts the carpets with a truckmounted system and does not leave squishy wet carpets. We offer a 30 day customer satisfaction guarantee incase of reappearing spots. We stand behind our work.
Chem-Dry is the world's leader for carpet and upholstery cleaning services, cleaning an estimated one billion square feet of carpet each year! What makes Chem-Dry the world's favorite carpet and upholstery cleaning service is our patented hot water extraction with the power of carbonation, exceptional customer service, and our ongoing research in cleaning technology.
By using Chem-Dry, you will have a drier, cleaner, and healthier home.
Carpet manufacturers require routine professional carpet cleaning to maintain warranty compliance.
Compare the Difference
Chem-Dry's patented Carbonating Cleaner is applied using a low pressure applicator that applies millions of microscopic carbonated bubbles into your carpet, then with the power of carbonation lifting the dirt and grime to the surface to be extracted and swept away forever. This process leaves your carpet in a drier and cleaner state, more than steam cleaning accomplishes.
Unlike the Chem-Dry process, steam cleaning frequently uses high pressure that forces water down through the carpet backing straight to the pad. This leads to buckets of water that can be left behind trapping soapy, dirt-attracting residue deeply imbedded in your carpet, creating the risk of reappearing spots and a potential breeding ground for mold and bacteria.
Chem-Dry Carbonation VS. Steam Cleaning
Chem-Dry (Hot Carbonation) Steam Cleaning (Hot Water Extraction)
Chem-Dry's System Steam Cleaning
(Chem-Dry) Carbonating, active cleaning solution
(Steam Cleaning) Flat, inactive cleaning solution
(Chem-Dry) Neutral pH cleaning solution
(Steam Cleaning) High pH cleaning solution
(Chem-Dry) Safe, non-toxic
(Steam Cleaning) Chemicals, surfactants, soaps
(Chem-Dry) Resists resoiling
(Steam Cleaning) Encourages resoiling
(Chem-Dry) Low water quantiy
(Steam Cleaning) High water quantity
(Chem-Dry) Low pressure application
(Steam Cleaning) High pressure application
(Chem-Dry) Short drying time
(Steam Cleaning) Long drying times = wet carpets and socks
