sweendogg
There is a cimex auto scrubber that utilizes the 19 inch planetary head, gravity feet solution tank, vacuum/squeegee/waste tank as well on ebay for $995.00 I'm betting it would work great for several purposes if the squeegee could be left up and the the vac motor turned off when need be.
A couple of ideas: Encapsulation, carpet scrubbing, hard Surface cleaning, Natural stone polishing... talk about faster maintenance.. if you are using monkeys pads or resin discs, would make clean up faster anyways.
http://cgi.ebay.com/Cimex-Eagle-walk-be ... 19c217641b
http://www.cimex-usa.com/pdf/Eagle_Complete.pdf
