Cimex scrub, Wand extract
Shorty
Cairns
Shorty Glanville
Following on from the many posts regarding Rotovacs, (all of them), RX20's, OP's & rotaries, I have not seen many posts where the operator has used a Cimex to scrub the carpet, then rinse/extracted with a wand.
Do many, or any of you, use this combination.??
If so, what do you think of the results.??
I have used this combination several times with my little truck mount, including scrubbing with the Mex, then rinse extracting with the old slow speed CMX20, and achieved brilliant results.
Thanks,
:roll:
ACE
Lawrence, KS
Mike Hughes
I have to do that every time at one of my restaurants with olefin carpet. It’s a good trick for extreme soil.
A
amazingcleansc
i dont see what would be horrible about doing releasit/cimex on carpet and then extracting with fresh water
ACE
Lawrence, KS
Mike Hughes
You need to use a prespray designed for HWE if you plan to HWE after a pre-scrub with the Cimex. Releasit and most encap products will foam up and kill your vacuum.
Zee
SoCal jungle
We have done the following hundreds of times: prespray with HF followed by cimex and then extract with truckmount (wand).
Brilliant results!
These days I prescrub -after my prespray is down- with my orbot and then extract.
A
amazingcleansc
Brilliant results!
i actually have really been enjoying using releasit ds and the cimex lately. Im going to show you what i did with an old la z boy chair on another thread
A
amazingcleansc
extraction powder foams up like a beyitch.
I think on second thought it might not be a good idea because releasit has flouro protector in it that you'd be rinsing up.
Ryan
For best results scrub then extract then encap the carpet. Takes a long time, but works wonders on extreme traffic lanes.
A
amazingcleansc
you arent taking into account the laziness factor AT ALL.
if youre going to be like that, then pile lift with a good stiff cylindrical brush machine first, vaccum then scrub prespray with a pad type machine.
and keep a pair of snips with you to get the odd out of place carpet fibers.
Dr Vapeur
Quebec, Quebec, Canada
Richard Gagne
I have been clean my chiro (about 2000 sq ft) for the past few years (my first commercial). The first time I did it with just a wand and prespray, looked good not perfect. The second time I used a sebo dual rotating scrubber, looked alot better. The last couple of time I used a cimex to scrub in the prespray. The difference blew me and my chiro away. Now, I always use the cimex to scrub. It does not take to much longer to do but does such a good job that I am proud of the carpet.
I have to thank this board for all the useful information.
Richard Gagne
floorguy
Utah
Doug
here ya go...a nasty Chinese place
Derek
NY
Derek
2-method cleaning will always beat a 1-method cleaning.
except for when the 2 methods are Capture followed by a Rug Dr.
I use the cimex scrub and rinse. Results are great of course. The only problem I have is that once u scrub with the cimex the carpet looks clean and therefore makes it hard to keep track of where I've been when rinsing.
lance
Thanks Richard. It seems that the white/tan pads are the most popular.
I have a Whittaker crb with blue brushes.....i think that might be a great scrubber just like the cimex. Great pics.
