Mike Draper
- Joined
- Jan 13, 2008
- Messages
- 4,402
this may have been brought up before. Has anyone here done this, what process did you guys use? Thanks
shellybrown said:If you want to clean your rubber flooring you should vacuum regularly with a wooden or plastic scraper. Do not use any type of metal scraper as it may scratch the flooring facade. Also a nylon scrub pad will help you to stroke off heel marks. Grease and Oil should not be left on rug for extended periods of time. Wash off as soon as possible and clean any rest with water and soap.
FredC said:I took the links out.
Mike Draper said:this may have been brought up before. Has anyone here done this, what process did you guys use? Thanks
