Client Complains About "Stripes"
bensurdi
Snohomish,WA
Benjamin Surdi
One of my guys was cleaning a house yesterday. I get a call from a upset client saying that we left stripes all over her carpet. So I asked her to send pictures of the stripes.
After looking at them, it seems like it is from the hybrid glide. Have you ever had a client complain about this? How did you handle that?
You are going to go back and reclean the carpet. This time make sure your jets are unplugged and aligned properly and the glide is not plugged.
Don't forget to take deep breaths, eat your fruit and vegetables and wash your hands after you poop.
bensurdi
Snohomish,WA
Benjamin Surdi
All jets are brand new and glide was not clogged is the problem. This is just wool carpet that was cleaned and the glide left this behind.
joe harper
florida
joe harper
At what temp & pressure..... :?:
You MAY own a peice of wool.... :shock:
Hoody
Bowling Green, Ohio
Steven Hoodlebrink
Years of Experience
20
bensurdi said:
Temp was 225 and the strokes look long because of the camera angle etc. Pressure was 500psi
Reclean, and use a carpet brush this time.
joe harper
florida
joe harper
I am NOT a wool expert...We get very little in fl..especially wall to wall... :oops:
But I would assume the heat & pressure has SET the yarn...!
That carpet at a minimum should have been groomed...!
Defiantly will need re-cleaning...Try a Host machine or a Whittaker to groom the lines out of it..!
This is NOT going to be acceptiable to the cleint...the lines HAVE to go..!!!
They are NOT going to be willing to VAC for months...waiting for the fibers to be more uniform
in appearance... :cry:
ps When we 1st started using a glide...We had clients SWEAR the wand was flawed & was NOT cleaning the carpet uniformly..."They assumed those were dirty STREAKS... :idea: "
Looks like jets are striking too close to the carpet, throw in high temp on delicate carpet and I'd be surprised if you can correct it to a pissed off clients satisfaction.
I'd cross your fingers, toes and ring the neck of the technician that continued to clean when there was clearly an issue.
Good luck!
Zee
SoCal jungle
Hopefully you can reverse that...reclean and you DON'T need that hot water to clean wool and you DON'T need that much pressure!
Just like oriental rugs- we don't wash them with high heat and high pressure. (Except a few)
You can wash a wool rug with pretty cool water in a washpit with low pressure flushing. So wall to wall wool shouldn't need that blasting to get it cleaned.
joe harper
florida
joe harper
Ben is making a BIG mistake....If he is trying to run a multi-truck operation with the BIG TRUCKS..!
It is like giving a 5 year old a 45 Magnum.... :roll:
When that kid gets HURT...& they will... :idea:
Them BLAME resides with the ADULT... :x
Ben ....Doesn't even have enough "experiance" to be hunting with the BIG GUNS... :oops:
bensurdi
Snohomish,WA
Benjamin Surdi
Harper are you talking to me or are you trying to give a speech to the others about my lack of experience?
I must know a little something about carpet cleaning to be running a 500K/per year outfit in under 3 years of being in operation and have one of the best reputations in our area...
What did your company look like after 3 years? In fact.... what does your company look like NOW.. with all of that experience???
Not trying to call you out or anything.. but your comments come across as if you are trying to insult me.
Heathrow
New Zealand
Heath Menefy
Ben I'm 99% sure that a final dry stroke would avoid leaving stripes. I clean wool every day using a hybrid - yes it will leave stripes if the last stroke is a wet stroke, but finish with a dry stroke and there'll be no need to groom. I'd say your guys should be using dry strokes on wool anyways.
joe harper
florida
joe harper
I was trying to HELP you ...you SnOt-NosEd PunK.... :shock:
The better "QUESTION IS"..."What will your company look like in 33 years..?" Iseeru
"I really don't think YOU want me to open up the PaNdOra'S box of your businesses "RECORD"
bensurdi
Snohomish,WA
Benjamin Surdi
How does commenting about me being inexperienced and saying I shouldn't be using AeroTechs come across as helpful?
Don't even bother responding i've got better things to do.
joe harper
florida
joe harper
"GOOD THINKING".... !gotcha!
"Best decision...you have made in a while.."
Shane Deubell
I have a hard time believing that?
Chris A
OH
Don't bother calling Ben out, you wont get anywhere...
KevinL
East Peoria Illinois
Kevin Leach
I don't care how good you are, you haven't cleaned enough carpet in 3 years to get a great reputation. Even if you've done 3 thousand jobs that is still a drop in any sized towns bucket.
Heathrow
New Zealand
Heath Menefy
Why don't you Fu##wits get over yourselves - is this the reason why most people here are lurkers?
:roll:
Benton KY USA
Richard nailed it. For this particular carpet jets were too close, pressure too high. You "flared" it, and should have noticed from the first stroke in the first room.
This will happen on frieze and other plush or "frizzy" carpets.
jcooper
IL
Jerry Cooper
Just needed to be groomed. 225 and 500 psi seem to be a little overkill...
joeynbgky
Bowling Green
Joey
Re: Client Complains About "Stripes"
Low heat on wool. Anyways 150 deg
Sent from my T-Mobile G2 using Tapatalk
Goomer
Bronx, New York
Frank Mendo
You guy's should be nicer to Ben.
Can't you see he is not only a "Carpet Care Specialist", but he is also a "President"?
