Cobb's Fabric Brightener Oxidizing Agent-what do you use it for???
curt johnson
Anthem AZ
Curt Johnson
So what exactly does one use this product for??? I bought it but now trying to remember why???
larger image
<a href="http://www.cobbcarpet.com/zen/index.php?main_page=popup_image&pID=1077" target="_blank"><img src="images/dcfb.gif" alt="Fabric Brightener Oxidizing Agent - Gallon" title=" Fabric Brightener Oxidizing Agent - Gallon " width="80" height="160" /><br /><span class="imgLink">larger image</span></a>
$13.95
Fabric Brightener - Oxidizing Agent
* New Hi-Strength Liquid Oxidizer for Stain Removal and Dingy Traffic Lanes.
* Booster for adding stain removal to presprays
* Breaks Down Pet Odors
* Removes Blood @ 50% strength (synthetic fibers)
* Removes natural dyes & organic stains when activated with high pH spotter.
* High Peroxide Strength 15% (50 Volume) + Stabilizers
Ships ORM D in Gallon Containers
Add to Cart:
  • Model: DCFB1
  • Manufactured by: Dynachem
Pre spot coffee, pet, soda or any other tough organic stains prior to cleaning
Post spotting
Boosting your pre spray
Mouth wash
Hand sanitizer
curt johnson
Anthem AZ
Curt Johnson
So on the bottle it says " don't mix with alkaline pre-spray".....I'm guessing we ignore that if boosting pre spray???
Do you only mix it when ready to use? Does it go bad when not used right away?
Dont mix it with boiling hot prespray is what it should say.
It will last more than a month in your van, opened or not.
40/50 is really over kill, 20 works fine most of the time but heat and light weaken it so might as well start strong and dilute.
Dallas, Texas USA
Curt;
It is fine mixing with alkaline presprays . . .
Once you have mixed it with an alkaline product, it has a limited shelf life as it releases oxygen.
Some difficult stains will require high peroxide concentrations.
I buy it by the case and use it for pet stains like USR from CTI. also wine and blood.
Sent from my iPad using Tapatalk HDII
mirf
New jersey
David Mirfin
Fills up that shelf of product I don't have room for in the truck.
San Francisco, CA
Mouth wash- If applied, may cause involuntary singing. Mostly of the high C variety.
Hand sanitizer- and whitener.
One can never be too careful. You do know that Mike is joking.
Right!??
Charlie Lyman
Meridian, ID
Charlie Lyman
I sprayed some on some pee spots yesterday. I went upstairs and cleaned some carpet while I let it sit and soak in. Pee spots were gone when I came back. I've tried to get these spots out before with no luck.
Reactions: Larry Cobb
You were fortunate. It's not a magic pee spot elixir.
However, it IS a good product to have on your van for all those little organic spots and stains.
I agree. I just don't want him to have unwarranted expectations. Boyles already got one dude thinking a water claw is going to work on GDC. I don't want another poor soul to be butt hurt.
Charlie Lyman
Meridian, ID
Charlie Lyman
For this situation it was worth trying. They wouldn't budge with other attempts. So the customer didn't have any expectations.
I think I will try it as a mouthwash. Maybe it will remove the coffee stains from my teeth.
Dallas, Texas USA
If you know what you are doing . . .
the Fabric Brightener can be used straight . . .
It must be monitored and rinsed at the appropriate time duration.
Fort Worth , Texas
I can see problems developing quickly.
I don't let my guys just spray it on anything straight but we are mostly janitors
