Cobb's Stain-Solv
Luis Gomez
Luis Gomez
Worked as advertised, but I wish that he and VacAway would spend a little more on their labels. They always run.
Ball point ink
After hand spotting
After rinsing
Ya I hit a canvass cotton which was a still raw with some seeds and on the inside of the cushion the bagged foam stuffing had a light blue stamp the came through the fabric lightly, I pulled out the inside hit it with stain solv came right off.
Put the stuffing back in with a plastic furniture chip between the stamp marking and the fabric.
I pre sprayed the couch with cobbs uph. pre spray 2 to 3 oz in a 64 oz sprayer and
a little dynachem brightner.
Rinsed with natural fiber cleaner and a little last step. let dry in the sun.
The pre spray got on my hands a bit.
Ya and the labels do bleed.
Reactions: Art Kelley
The frame was completely white when dry just looked ugly when wet.
We have switched to a chemical resistant quart bottle . . .
with an UV-cure ink screen print (best available) .
Glad the product is working well for you.
Reactions: dgardner
handdi
Randy
yes i used a bottle sat one customer had lots of ink stains the other spilled a bottle of blue finger nail polish on her carpet in the lr
made me look like a hero for sure.
good stuff...I have it on both trucks.......its not 100% but nothing is......but.....it will remove more things then anything out there........
CTI Pro Solve
Hel Gel
Cobbs
Alcohol
not sure you need much more than those.
It has a time limit to keep people from going on deleting sprees.............or you're not in a usergroup with permissions
Have you considered becoming a Supportive Member Larry? I could send you some literature.......
