Jamesh921
Anybody ever compared Cobb's Powermax to his Citrus Steam Powder?
Just wonderin' how they stack up against each other.
There are alot better pre sprays out there that give you more bang for your buck than powermax. I have tried to give pm the benefit of the time after time and never seem to be that impressed by it.
The difference is the oxidizer,
which will brighten up dingy traffic lanes and remove coffee stains.
I use PB now. Never needed to change.
Johnny said:I prefer a prespray without delim and oxy. I'll add delim and/or oxy as required. Not every situation calls for the same level of additives.
Does Larry make a good powdered prespray without delim and oxy?
In my experience , I would continue using power burst over power max .Clnthred said:Could I get a small sample to use on our Japanese restaurant we do ever five weeks. Only enough to fill a hf will do. I use PB now. Never needed to change.
Would be willing to post pictures and video.
AJ RUIZ said:thanks for the input. Funny thing is that I am a junior also, lol. must be us junior's. if you add 2-4 oz. powermax per gal in pump up sprayer then how do you get 12 oz. to a 5 qt. hydro with an 8 to 1 tip? I may have this wrong but I figure 5 qt. mix to 40 qts water (1 to 8) for a total of 45 qts or 11.25 gal. at the recommended 2 oz. powermax per gal. shouldn’t we be using 23 oz of powder to a 5qt hydro. with 1 to 8 tip? again if I am wrong in my calculations I apologize in advance.
wow 24 oz in a hf is alot of powder to cram in there. I dont know about you guys but I have a hard time mixing all that especialy on the flyKevinD said:AJ RUIZ said:thanks for the input. Funny thing is that I am a junior also, lol. must be us junior's. if you add 2-4 oz. powermax per gal in pump up sprayer then how do you get 12 oz. to a 5 qt. hydro with an 8 to 1 tip? I may have this wrong but I figure 5 qt. mix to 40 qts water (1 to 8) for a total of 45 qts or 11.25 gal. at the recommended 2 oz. powermax per gal. shouldn’t we be using 23 oz of powder to a 5qt hydro. with 1 to 8 tip? again if I am wrong in my calculations I apologize in advance.
I have always used 3 cups (24ounces) in my 1:8 hydroforce.
Been doing it for years and it all dissolves and I never have resoiling issues.
We are working hard to maintain that unique fragrance that you like in the PowerMax.AJ RUIZ said:. . . the powermax smells great when i handle it but not to much when i am spraying it down.
Jamesh921 said:There are alot better pre sprays out there that give you more bang for your buck than powermax. I have tried to give pm the benefit of the time after time and never seem to be that impressed by it.
So, what prespray do you use, if you don't mind me asking?
I like cti extreme clean. 2 oz per gallon , 4- 5 scoops in my hf without tip, mixes well even in cold water and does great on the nasties. Cost me about .35-,0.40 per rtu gallon.Plus it ships on time and each batch has always been consistant for the last 6 years I have used it. I also like it because I can boost with oxidizer or d limo as I see fit
[quote:3rrvxkqo]The difference is the oxidizer,
