CTI EXTREME CLEAN
Goomer
Cleaning Professional
Frank Mendo
I am surprised this stuff does not get a lot of mention here.
It consistently blasts through everything I come across and smells GREAT.
How many of you guys use this as your go-to prespray??
godzilla
ME!!!! It rocks. Was afraid to use it at first on residential, only used it on apartment nasties, But I soon got over it and now will use it on anything. Works for me.
ACE
I Use it about 50% of the time. Great Stuff!
I use Redline if it’s a Nylon and I don’t see need to risk striping the stain resistance.
If I’m sure it’s Poly or Olefin and it’s trashed, I Use Kleanrite High pH (pH 13.2)
I just went back to using it in certain situations of really dirty carpets.
I used to use it on apartments and was very impressed.
Since it's a DUAL use product, you can use it either as a prespray or in tank EMULSIFIER.
I use it as a EMULSIFIER and it rocks.
No problem with too high of a ph and I only use half the amount called for.
But you babies are afraid of warrantees aren't we?
But nobody cares about them and especially if they are TRASHED anyway.
So BinGO BanGo BoNgO in and out like some GanGstA Thug whose robbing the place.
Hoody
Cleaning Professional Gold Member
Steven Hoodlebrink
Bowling Green, Ohio
Years of Experience
21
Website
Visit Website
Love the stuff, its great for apartments.
juniorc82
I have used it off and on for 7 years. I still keep a jar around but since I have opened a supply store I just use my house brand for everything except the nasties
daniel@procarpet
You know that stuff will eat a chem pump super fast. Best not run it through your machine. Use it as a prespray.
That's just what I have heard from several people that had to replace their chem pumps.
They have since switched to dry slurry which is a far better rinse agent.
Jtuseo
Extreme clean is the best product made. Everything made by cti is top notch.
juniorc82
......And cobb should be swooping in here any second know....... :lol: :lol: .......
It doesnt eat chemical pumps! the dilemonene can break down the rubber diaphragm!
If You add any solvent straight to your rinse it can do that.
I like DFC105 as a rinse less residue then slurry actually no res, but for nasties extreme clean as a prespray rinse combo can speed things up considerably.
A gallon of liquid slurry cost $30.00 a gallon of dfc runs $15.00
The slurry has a more punch but with a good prespray all things are equal.
Jim Williams
Jim Williams
I used Extreme clean last week after I ran out of Cobbs stuff and needed to buy something local due to shipping times from Texas. I have to say it is awesome! And it seems to have less orange in it so the cuts and dry skin on my hands are actually starting to heal. At 2 oz. per gallon it is just as good of a value as any out there. It also doesn't feel sticky at all so I'm guessing resoiling will not be an issue.
John Olson
John Olson
I sell 25-30 5 gallon buckets of it a month and have for 9 years straight.
plus the 10-15 cases for the jars each month. For a small guy that carries multiple lines this speaks volumes as to how good the product is.
It says on the label it can be used as a EMULSIFIER.
I don't have a chem pump.
And when I did the diaphram would always go out anyway no matter what I used.
AndyKramer20
I hear that John I am just a small store in Wisconsin and probably my most favorite product is the extreme clean and redline from masterblend.
Louis
Louis
I have used it for years. Always works great. I always use it as a prespray. If it is bad give it 15 minutes or scrub it in, no need for injection. I have mixed with cobbs before and it worked even better.
West
Clint
Great stuff, have lots of yellow pails kicking around
