- Joined
- Sep 26, 2008
- Messages
- 3,556
- Name
- Russ Terhaar
I am losing heat recently at my wand. The last time I descaled, it cured the problem. In the past I've used muriatic acid but have read enough to think I should try the powder from Prochem. I want to be doing this right. I have a smaller slide in from a company called Chem Tex. It has last step chemical injection. It regulates its temp by dumping hot water into the dump tank. It has a water box (mix tank) that holds a couple gallons.
I saw a video on YouTube where a guy is descaling a hydramaster by essentially creating a loop with his solution line. He has an adaptor which allows him to plug his pressure outlet into the water box input so he is looping the acid through the system. Could anyone help with any suggestions? My machine is pretty basic but it cleans really well and I want to keep it that way for a long time. Thanks for your time!
Russ "The Clean Machine".
