So after poking around in pressure washer forums, (because it is after all a PW heater)
I found just how intense I needed to be with this coil....
None of this run it through the machine and let it sit for a day....NOOOOOO
Put the juice in, run it for 15 min...let it sit....run it some more, sit....flush...run some more through.... etc....
So i wasnt going to run the machine with this shit in it...caustic wise or the shit that came out....
So i had a pump laying around from my old porty turned presprayer
Got the clear hose so i could see what was flowing....figured it pressed pretty good on the barbs...low pressure...who needs clamps
oh and then the pump wouldnt pull.... so had to rig a bucket with a fitting to gravity feed it
So all is pumping just fine (about a minute) when i notice the pump leaking (ohhhh so thats why i pulled it out)
go to move the pump above a bucket (ohhh so thats why you use clamps....)
freaking acid water spitting everywhere...... At least I didnt get any on me..(now where are those gloves and glasses )
So after i cleaned that up, tried another one i had sitting there....damnit it doesnt even work WTF
So decided fook it...the prespray machine it is...and if i screw this pump up....well i got another one on the shelf...(and it is new so stfu)
And it was working well...good pressure, clean working....till on a rinse....POP goes the hose from out of the machine.....(hell didnt even like 100psi)
Thinking Thinking..... AH HA...I got a wire reinforced clean one over on this old machine....
acid, sit, rinse, REPEAT.....
after all is said and done....it is fixed...has a nice stream to it...(remember i said it looked like it was dribbling....now we got full on stream)
and now I have some parts made up, for me to do it again, in the spring, or right before i hook up my softener I will be getting....
Moral of the story....
Go with your fist gut thought....(was gonna use the machine..but thought nawwwwww)
and over do it on the hose ALWAYS!!!!!!!!!!!!!!!!!
