Oct 14, 2008 #1 Larry B Member Joined Jun 23, 2008 Messages 2,903 Location Pigeon Forge, TN Name Larry Burrell What size thermostat do you run on your van motor? 180? 185? 210? higher? What temp do you get at the wand from heat exchangers?
Oct 14, 2008 #2 bob vawter Grassy Knoller Joined Sep 15, 2007 Messages 43,755 Location La La Land Name bob vawter I run a 205...and what is....IS!
Oct 14, 2008 #3 TimP Member Joined May 19, 2007 Messages 4,055 Mine is what comes with the van I'm sure.....probably 185-195 somewhere around there.....
Oct 14, 2008 #4 AshleyMckendree Supportive Member Joined Sep 1, 2007 Messages 1,572 Location Versailles ky Name Ashley Mckendree 210... BIG navistar diesel engine likes the heat.
Oct 14, 2008 #5 M Mr.V Member Joined Aug 2, 2008 Messages 199 I'm running a cleanco with a factory thermostat in a 2008 chevy van,,,,machine has the high heat option it'll stay around 220-230 and in summer get up to 240
Oct 14, 2008 #6 J joey895 Supportive Member Joined Oct 7, 2006 Messages 2,436 Location Florida Name Joey J. I'm running a 205 in mine.
Oct 14, 2008 #7 Mike Draper Member Joined Jan 13, 2008 Messages 4,402 First off......if your running a direct drive gasoline, where do you get a higher thermostat than 195 deg? I Can't find one anywhere.
Oct 14, 2008 #8 Larry B Member Joined Jun 23, 2008 Messages 2,903 Location Pigeon Forge, TN Name Larry Burrell Carpet van 195 my jeep 210
