Oct 14, 2008 #1 L Larry B Guest What size thermostat do you run on your van motor? 180? 185? 210? higher? What temp do you get at the wand from heat exchangers?
Oct 14, 2008 #2 bob vawter Grassy Knoller Joined Sep 15, 2007 Messages 44,637 Name bob vawter I run a 205...and what is....IS!
Oct 14, 2008 #3 T TimP Guest Mine is what comes with the van I'm sure.....probably 185-195 somewhere around there.....
Oct 14, 2008 #4 AshleyMckendree Supportive Member Joined Sep 1, 2007 Messages 1,572 Name Ashley Mckendree 210... BIG navistar diesel engine likes the heat.
Oct 14, 2008 #5 M Mr.V Guest I'm running a cleanco with a factory thermostat in a 2008 chevy van,,,,machine has the high heat option it'll stay around 220-230 and in summer get up to 240
Oct 14, 2008 #6 J joey895 Supportive Member Joined Oct 7, 2006 Messages 2,435 Name Joey J. I'm running a 205 in mine.
Oct 14, 2008 #7 M Mike Draper Guest First off......if your running a direct drive gasoline, where do you get a higher thermostat than 195 deg? I Can't find one anywhere.
